  • New LITTLE FOOT� Plus Driver Products for High- and Low-Side DC-DC Operation Integrate MOSFETs and Drive Circuitry in 10-mm by 6.2-mm Footprint
Jun 11, 2003
SANTA CLARA, Calif. -- February 10, 2003 -- Five new LITTLE FOOT Plus Driver products designed to simplify the use of n-channel MOSFETs in high-frequency buck regulators were announced today by Siliconix incorporated (NASDAQ: SILI), an 80.4% owned subsidiary of Vishay Intertechnology, Inc. (NYSE: VSH).
With efficiencies better or comparable to competing implementations in the MLF/QFN/Power Block packages, these new devices in the LITTLE FOOT SO-16 feature a 38% or smaller standard footprint, simplifying design, assembly, soldering, and layout.
The n-channel Si4738CY (20 V), Si4770CY (20 V), Si4724CY (30 V), Si4732CY (30 V), and Si4768CY (30 V) synchronous MOSFETs with integrated driver circuitry are designed to extend battery life and/or enable more efficient use of power. Applications will include high-frequency, multi-phase dc-to-dc switchmode power supplies for CPU core, graphics control, chipset, and auxiliary power in systems including desktop computers, servers, workstations, notebook computers and tablet PCs, and point-of-load (POL) applications for fixed telecom systems.
With optimized on-resistance values and �shoot-thru� protection for low-side operation, and gate-to-drain Q optimization for high-side operation, the new devices provide high efficiency while enabling an integrated board layout with significant space savings over discrete solutions.
By integrating two MOSFETs and a driver in a compact SO-16 package, the Vishay Siliconix devices released today offer reduced gate-drive losses and higher switching frequencies while simplifying board layout and allowing designers to implement less-complicated controller solutions. The Si4724CY also features an integrated Schottky diode, further reducing the number of components required on the printed circuit board.
Each device features a switching frequency of up to 700 kHz+, driver impedance of 1 or 3 ohms, and operation down to 4.5 V, as well as break-before-make action and under-voltage lockout.
Samples and production quantities of the new LITTLE FOOT Plus Driver products are available now with lead times of 10 to 12 weeks for larger orders. Pricing for U.S. delivery in 100,000-piece quantities ranges from $2.10 to $2.92.
Siliconix, a company of Vishay Intertechnology, Inc., is a leading manufacturer of power MOSFETs, power ICs, and analog switches for computers, cell phones, fixed communications networks, automobiles, and other electronic systems. With 2001 worldwide sales of $305.6 million, the Company's facilities include a Class 1, six-inch wafer fab dedicated to the manufacture of power products in Santa Clara, California, and an affiliated Class 1, six-inch wafer fab located in Itzehoe, Germany. Power products are also manufactured by a subcontractor in Japan. Analog switches, analog multiplexers, and low-power transistors are fabricated by subcontractors in Dresden, Germany, and in Beijing, China. Assembly and test facilities include a company-owned facility in Taiwan, a joint venture in Shanghai, China, and subcontractors in the Philippines, China, and the United States.
Vishay, a Fortune 1,000 Company listed on the NYSE, is one of the world's largest manufacturers of discrete semiconductors (diodes, rectifiers, transistors, optoelectronics, and selected ICs) and passive electronic components (resistors, capacitors, inductors, and transducers). The Company�s components can be found in products manufactured in a very broad range of industries worldwide. Vishay is headquartered in Malvern, Pennsylvania, and has plants in sixteen countries employing over 25,000 people. Vishay can be found on the Internet at http://www.vishay.com.
Note to editors: A previous version of this release moved over BusinessWire on February 5.
LITTLE FOOT� is a registered trademark of Siliconix incorporated.
Agency Contact:
Bob Decker
Wall Street Communications
Telephone: 1-215-209-0233
Email: bob.decker@wallstcom.com
READER CONTACT INFORMATION
THE AMERICAS
Vishay Siliconix
2201 Laurelwood Road
Santa Clara, California 95054
+1-619-336-0860
info@vishay.com
www.vishay.com
EUROPE
Ms. Marian Neil
Vishay Ltd.
Pallion Industrial Estate
Sunderland SR4 6SU
United Kingdom
Telephone: 44 191 5144155
Facsimile: 44 191 5658245
Ms. Margarete Seeharsch
Vishay-Semiconductor GmbH
Theresienstrasse 2
74072 Heilbronn
Germany
Telephone: 49 71 31 67 2831
Fax: 49 71 31 67 2423
Ms. Nathalie Caoudal
Vishay S.A.
4, rue de Salonique
95101 Argenteuil
France
Telephone: 33 1 39 98 22 56
Fax: 33 1 39 98 22 20
ASIA/PACIFIC
Ms. Sandra Sim
Vishay Intertechnology Asia Pte. Ltd.
Keppel Building #02-00
25 Tampines Street 92
Singapore 528877
Rep. of Singapore
Telephone: (65) 6780-7849
Fax: (65) 6788-0988
Jul 06, 2010 -
Feb 14, 2007 -
Feb 14, 2007 -
Feb 24, 2006 -
Feb 24, 2006 -
Feb 24, 2006 -
Dec 15, 2005 -
Dec 06, 2005 -
Dec 06, 2005 -
Nov 29, 2005 -
Sep 16, 2024 -
Essemtec Wins 2024 Mexico Technology Award for Excellence in Dispensing Technology
Sep 16, 2024 -
Impossible Objects' Flagship Industrial 3D Printer, The CBAM-25 Wins 2024 Mexico Technology Award for 3D Printing
Sep 16, 2024 -
Sep 16, 2024 -
Stannol Wins Two Mexico Technology Awards for Flux and Solder Wire Innovations
Sep 16, 2024 -
Author Jairek Robbins to Discuss Leadership and Legacy in the Manufacturing Industry During the Keynote Address at SMTA International and The ASSEMBLY Show
Sep 16, 2024 -
Nordson Test & Inspection Honored with Technology Award for SQ3000M2
Sep 16, 2024 -
Apollo Seiko Mexico Triumphs with the STARGATE Laser Soldering Unit at the 2024 Mexico Technology Awards
Sep 16, 2024 -
Altus Hosts Record-Breaking 'Factory of the Future' Event
Sep 16, 2024 -
SMTVYS Technology's Victor Madero Earns Best Mexico Sales Rep Award
Sep 16, 2024 -
ViTrox Technologies' ViTrox V810i Advanced AXI System - Series 3 Dual-Lane Wins Industry Award for Innovation
New LITTLE FOOT� Plus Driver Products for High- and Low-Side DC-DC Operation Integrate MOSFETs and Drive Circuitry in 10-mm by 6.2-mm Footprint news release has been viewed 814 times
