Vishay Siliconix New 150-mA LDO Regulators in Small SC-70 Package
Aug 03, 2005
MALVERN, Pa. -- Aug. 1, 2005 -- Vishay Intertechnology, Inc. (NYSE: VSH) today announced two new 150-mA low-noise low-dropout (LDO) regulators with the highest available current density in the small five-pin SC-70 package. Their extremely small 2 mm by 2 mm footprint makes them well-suited for use in battery-powered equipment such as cell phones, PDAs, pagers, digital cameras, MP3 players, cable and DSL modems, and other noise-sensitive electronics.
Under a 150-mA load condition, the SiP21101 and SiP21102 feature an extraordinarily low dropout of 130 mV and a ground current of 110 microamps, helping to prolong battery life in low-voltage portable electronic systems. Designed to maintain regulation while delivering 300-mA peak current, the new ICs both feature a fast start-up time of 50 microseconds, making them an excellent choice for systems that have a high surge current upon turn-on. Fifteen fixed output voltage options ranging from 1.2 V to 5.0 V are available.
The SiP21101 can be used as a pin-for-pin replacement, with significantly improved current handling, for the MAX8510 and MIC5253.
An active pull-down circuit is built into the devices to clamp the output voltage when it rises beyond normal regulation, discharging it automatically by connecting the output to ground through a 100-ohm n-channel MOSFET when the device is put in shutdown mode. This provides better transient response and regulation. Reverse battery protection limits the reverse current flow to approximately 1 microamp to prevent damage to the IC in the event that a reversed battery is applied at the input. Short circuit and thermal protection are also built in.
The SiP21101 provides an extremely quiet voltage source because of an external noise bypass capacitor connected to its BP pin that reduces noise to only 30 microvolts, a significant benefit for RF applications. The same pin on the SiP21102, which has a noise output of 75 microvolts, functions as an error flag output that goes low when the output voltage drops 4% below its normal voltage.
The SiP21101 and SiP21102 use low-cost ceramic capacitors or tantalum capacitors, giving designers a flexible choice of magnetic components.
Samples and production quantities are available now for most voltage options, with lead times of 6 to 8 weeks for larger orders. Pricing is $0.40 each in 1,000-piece quantities.
Vishay Intertechnology, Inc., a Fortune 1,000 Company listed on the NYSE (VSH), is one of the world's largest manufacturers of discrete semiconductors (diodes, rectifiers, transistors, and optoelectronics) and selected ICs, and passive electronic components (resistors, capacitors, inductors, and transducers). Vishay's components can be found in products manufactured in a very broad range of industries worldwide. Vishay is headquartered in Malvern, Pa., and has operations in 17 countries employing over 25,000 people. Vishay can be found on the Internet at http://www.vishay.com.
Links to product datasheets:
http://www.vishay.com/doc?73212 (SiP21101)
http://www.vishay.com/doc?73213 (SiP21102)
Link to product photo:
http://www.wallstcom.com/vishay/sip21101.zip
Editorial contact:
Bob Decker, Wall Street Communications (+1 415 409-0233, bob.decker@wallstcom.com)
Reader contact:
E-mail: info@vishay.com
Web: http://www.vishay.com
Phone (samples): 1 619 336-0860
Jul 06, 2010 -
Feb 14, 2007 -
Feb 14, 2007 -
Feb 24, 2006 -
Feb 24, 2006 -
Feb 24, 2006 -
Dec 15, 2005 -
Dec 06, 2005 -
Dec 06, 2005 -
Nov 29, 2005 -
Jun 13, 2024 -
Jun 12, 2024 -
Jun 11, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Vishay Siliconix New 150-mA LDO Regulators in Small SC-70 Package news release has been viewed 681 times
Manufacturing Software
