  • Vishay's New Dual-Output LDO Regulators With 48-Microamp Ground Current Convert 2.25-V to 5.5-V Inputs to Outputs as Low as 1.5 V at Current Levels of 150 mA and 300 mA
Dec 06, 2005
Vishay Intertechnology, Inc. (NYSE: VSH) today announced the release of four compact dual-output low-dropout (LDO) regulators capable of converting 2.25-V to 5.5-V inputs to outputs as low as 1.5 V at current levels of 150 mA and 300 mA. Operating with exceptional efficiency, the new devices provide a low ground current of 48 microamps.
The new SiP2210, SiP2211, SiP2213, and SiP2214 LDO regulators are designed to provide space savings and enhanced electrical performance in portable electronic devices such as cell phones, PDAs, MP3 players, and wireless modems.
Each part is available in a choice of two lead (Pb)-free packages: a very small 3-mm by 3-mm MLP33-10 PowerPAK package with a fixed output or a MLP44-16 PowerPAK� package with an adjustable output. All four devices are capable of supplying 150 mA from output 1 and 300 mA from output 2.
The SiP2210 and SiP2211 are pin-for-pin replacements for the MIC2210 and MIC2211 and are rated for a low dropout voltage of 65 mV at 100 mA and low ground current. Both feature independently enabled outputs, and the SiP2210 also includes an additional open-drain driver output capable of sinking 150 mA, as well as integrated POR (power-on reset) protection.
The SiP2213 and SiP2214 are pin-for-pin replacements for the MIC2213 and MIC2214. In the SiP2213, the outputs are sequenced at power on, with output 1 settling before output 2 begins turning on. Both devices also feature an open-drain driver output capable of sinking 150 mA, as well as POR protection with an adjustable delay that can be set to alert the processor when the output of the regulator has reached and settled at its designated voltage.
In addition to low dropout values and low power consumption, the new devices offer extremely low noise of 30 �V with the addition of a bypass capacitor. Protection features include undervoltage lockout, output-current limiting, and thermal shutdown.
Samples and production quantities of the SiP2210/11/13/14 are available now, with lead times of seven to eight weeks for larger orders. Pricing for U.S. delivery starts at $0.70 in 10,000-piece quantities.
Vishay, a Fortune 1,000 Company listed on the NYSE, is one of the world's largest manufacturers of discrete semiconductors (diodes, rectifiers, transistors, optoelectronics, and selected ICs) and passive electronic components (resistors, capacitors, inductors, and transducers). The Company's components can be found in products manufactured in a very broad range of industries worldwide. Vishay is headquartered in Malvern, Pa., and has operations in 17 countries employing over 25,000 people. Vishay can be found on the Internet at http://www.vishay.com.
PowerPAK is a registered trademark of Siliconix incorporated
Editor resources:
Links to product datasheets:
www.vishay.com/doc?73441 (SiP2210)
www.vishay.com/doc?73479 (SiP2211)
www.vishay.com/doc?73190 (SiP2213)
www.vishay.com/doc?73191 (SiP2214)
Link to product photo:
http://www.wallstcom.com/vishay/sip2210.zip
Editorial contact:
Bob Decker, Wall Street Communications (+1 415 409-0233, bob.decker@wallstcom.com)
Reader contact:
E-mail: info@vishay.com
Web: http://www.vishay.com
Phone (samples): +1 619 336-0860
Jul 06, 2010 -
Feb 14, 2007 -
Feb 14, 2007 -
Feb 24, 2006 -
Feb 24, 2006 -
Feb 24, 2006 -
Dec 15, 2005 -
Dec 06, 2005 -
Nov 29, 2005 -
Nov 29, 2005 -
17 New Siliconix PowerPAK 1212-8 Power MOSFETs Offer Superior Thermal Performance in DC-to-DC Applications
Jul 19, 2024 -
Koh Young to Host SMTA Atlanta Chapter Technical Meeting on State-of-the-Art Test Techniques presented by Vaughan Carlson from VALUE Engrafting
Jul 19, 2024 -
Electronica 2024: Where Vision Meets Reality
Jul 18, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Vishay's New Dual-Output LDO Regulators With 48-Microamp Ground Current Convert 2.25-V to 5.5-V Inputs to Outputs as Low as 1.5 V at Current Levels of 150 mA and 300 mA news release has been viewed 1044 times
Facility Closure
