Ersa presents brand new products at SMT/Hybrid/Packaging 2016
Mar 30, 2016
The VERSAFLOW 3/45 in-line selective soldering machine.
Ersa GmbH, the largest supplier of soldering equipment, is pleased to announce that it will exhibit a wide range of industry leading technologies in Hall 7, Booth 117 at the upcoming SMT/Hybrid/Packaging show, scheduled to take place April 26-28, 2016 at the Messe in Nuremberg, Germany. Additionally, the company will exhibit the VERSAFLOW3/45 with VERSASCAN and VERSAEYE for the first time.
The VERSAFLOW 3/45 is the first in-line selective soldering machine with dual track transport. Highest flexibility and highest throughput can be realised with the smallest possible required space. Already an industry favorite, the 3/45 is now equipped with VERSASCAN and VERSAEYE. The VERSASCAN module recognizes multicodes on printed boards, product carrieres or printed boards that are not fully or wrong assembled. These "bad boards" will be excluded from the processing. This saves resources and cycle time and leads to a clearly increased productivity. The VERSAEYE gives information about the solder joint: good or bad. The VERSAEYE is system optimized for wave and selective solding systems, is compatible with work piece carriers, and makes modular inspection possible: bottom, top or bottom & top. VERSAEYE is also available with up to 9 cameras per module.
Also on display at the show, Ersa’s new VERSAFLOW 4/55: the ideal selective soldering system for large and complex board assemblies in electronic manufacturing. Because of its modular design and depending on the demands additional flux, preheat and solder modules can be integrated. All modules run autonomously through their configured programs. Set-up times and operator interventions are not required, so the system can always operate at the highest level of productivity and process flexibility.
Stop by Ersa’s booth to see the Ersa Hotflow 3/20 VOIDLESS, Ersa presents a process efficient solution to minimize the occurrence of voids, which is characterized by its high throughput in inline operation, short process times and low operating costs. The VOIDLESS module, for which no additional maintenance is required, can be activated /deactivated at any time and reduces the occurrence of voids when compared to other soldering processes by up to 98 percent.
The Ersa stencil printer VERSAPRINT S1-3D combines precise stencil printing and 100 percent 3D-SPI in one system – featuring the smallest footprint. The VERSAPRINT stencil printers with integrated 100 percent post-print inspection have successfully established themselves in today’s market for electronic manufacturing equipment. Extending 2D inspection, Ersa now presents the VERSAPRINT 3D-SPI – with even more process control and still minimal floor space requirements.
The HR 550 Powerful Hybrid Rework System provides high performance rework for professionals. Highly efficient with a 1.500 W hybrid heating head, the large-area IR bottom has heating in 3 zones, and the HR550 boasts an integrated vacuum pipette for component removal and placement. Highly accurate placement with integrated force sensor and computer aided component adjustment make this a powerful rework system.
Finally, the I Tool HP 250 with i-Tool High Power 250W will be on display in Ersa’s booth. With the i-TOOL HIGH POWER Ersa has developed an extremly powerfull 250 W soldering iron that can be operated with the successful Ersa multi-channel soldering and desoldering stations i-CON VARIO 2 and 4. Meanwhile the operator can all in all use ten different tools for soldering and desoldering for this stations.
To see these leading technologies and more, stop by Hall 7, Booth 117 at the show, or visit www.ersa.com.
Ascentron Upgrades Entire Hand Soldering Line to Ersa i-CON 1 MK2
Jul 22, 2024 -
Jul 01, 2024 -
Kurtz Ersa Announces Upcoming VERSAFLOW 3 – Level II Training Opportunities in Plymouth, WI
May 20, 2024 -
Kurtz Ersa Announces Next VERSAFLOW 4 – Level ll Maintenance and Application Training Courses
May 13, 2024 -
Comtree to Present Kurtz Ersa's Proven IR Rework Technology at the SMTA Ontario Expo
May 13, 2024 -
Kurtz Ersa to Showcase Innovative IR Rework Technology at EPTECH Vancouver 2024
Apr 03, 2024 -
Kurtz Ersa to Offer Ersa VERSAFLOW 3 – Level ll Maintenance and Application Training Courses in April
Mar 18, 2024 -
Kurtz Ersa Inc. Receives 2024 CIRCUITS ASSEMBLY NPI Award for the VERSAFLOW ONE X-Series
Mar 18, 2024 -
Revolutionizing Soldering: Kurtz Ersa to Debut Cutting-Edge Lineup at APEX
Mar 11, 2024 -
Explore Superior Rework & Soldering Technology from Kurtz Ersa at EPTECH Toronto
302 more news from kurtz ersa Corporation »
Aug 09, 2024 -
Ersa presents brand new products at SMT/Hybrid/Packaging 2016 news release has been viewed 915 times
