  • Ersa Pushes for Smarter Systems – One Step Closer to Artificial Intelligence
Feb 12, 2018
Kurtz Ersa North America, a leading supplier of electronics production equipment, is pleased to announce that it has developed several new features for its selective solder equipment, including VERSASCAN, VERSAEYE and Ersa CAD Assistant 4. The VERSASCAN module can look at boards being presented to the machine and confirm if all of the components are on the board and if the polarity is correct before they enter the machine. This can be paired with another feature called VERSAEYE that looks for any defects on the board. Finally, Ersa CAD Assistant 4 offers intuitive and automated offline programming with a graphical user interface and template library.
The VERSASCAN feature consists of an X-Y axis system that is integrated into the modular machine design. Its camera unit enables the recognition of up to nine multi-codes as well as Bad Board recognition and the PCB direction. By Bad Board Detection, reject parts are detected and not further processed. The feature checks to see if the board is complete with the correct components placement and orientation of the board.
The VERSAEYE module is optimized for the inspection of THT solder joints and is, as a separate module, attached to the soldering system directly after the last soldering module. It can be equipped with up to nine cameras – one bottom and eight side cameras. The VERSAEYE can move in x-, y- and z- directions to enable an all-around inspection of the solder joints at a 45° angle. Highlights include:
  • System optimized for wave and selective soldering systems
  • Compatible with work piece carriers
  • Modular inspection possible: bottom, top or bottom & top
  • Available with up to 9 cameras per module
  • I/O interface
  • Classification of inspection results at all times
Ersa’s solder program editor CAD Assistant 4 makes programming a fast, intuitive and comfortable process. It enables programming offline, while the machine is running. Compatible CAD formats like ODB++ and other 3D/2D sources make programming much easier and safer. These programs can be used without any detours directly on the machine because of the full integration with the operating software of the machine, ERSASOFT 5.
“These features are allowing us to get closer to almost autonomous soldering systems with intelligence built in,” commented Albrecht Beck, President of Kurtz Ersa NA. “We are striving to exceed the market needs in the dynamic world of electronic soldering.”
For more information about Kurtz Ersa North America, visit www.ersa.com.
Ascentron Upgrades Entire Hand Soldering Line to Ersa i-CON 1 MK2
Jul 22, 2024 -
Jul 01, 2024 -
Kurtz Ersa Announces Upcoming VERSAFLOW 3 – Level II Training Opportunities in Plymouth, WI
May 20, 2024 -
Kurtz Ersa Announces Next VERSAFLOW 4 – Level ll Maintenance and Application Training Courses
May 13, 2024 -
Comtree to Present Kurtz Ersa's Proven IR Rework Technology at the SMTA Ontario Expo
May 13, 2024 -
Kurtz Ersa to Showcase Innovative IR Rework Technology at EPTECH Vancouver 2024
Apr 03, 2024 -
Kurtz Ersa to Offer Ersa VERSAFLOW 3 – Level ll Maintenance and Application Training Courses in April
Mar 18, 2024 -
Kurtz Ersa Inc. Receives 2024 CIRCUITS ASSEMBLY NPI Award for the VERSAFLOW ONE X-Series
Mar 18, 2024 -
Revolutionizing Soldering: Kurtz Ersa to Debut Cutting-Edge Lineup at APEX
Mar 11, 2024 -
Explore Superior Rework & Soldering Technology from Kurtz Ersa at EPTECH Toronto
302 more news from kurtz ersa Corporation »
Ersa Pushes for Smarter Systems – One Step Closer to Artificial Intelligence news release has been viewed 1304 times
