BEST Developes Revolutionary Gel for Masking of Parts
Jan 05, 2016
Rolling Meadows, IL – Rolling Meadows, IL – BEST, Inc., a leader in the development of PCB rework tools, announces the release of HeatShieldGel™ a water-based gel that protects components from heat. This revolutionary product, made from a water-based gel, easily goes on to parts neighboring the device to be reworked or on heat-sensitive devices such as ceramic capacitors that will be subject to reflow. After the rework or reflow process has been completed, the gel can be simply cleaned off with water. It is highly flexible in that it can be used on boards with tightly-spaced components without having to do any cutting or modification of shielding tape or materials.
The HeatShieldGel™ is effective and does not impact the reliability of the PCB. It is more effective than Kapton™ tape by a factor of 4X! It has shown to be innocuous to the PCB through thorough ionic cleanliness testing assuring you that when cleaned up properly the reliability of the board will not be impacted by using this product. The material is a single use water soluble clay-based, environmentally-safe formulation. It is non-flammable, non-toxic and does not have any corrosive properties.
One of the other beneficial attributes of this material is its flexibility and ease of use. Simply scoop out some of the gel material from the container. Apply it liberally to the parts requiring protection in the vicinity (not on the part being reflowed or it will not go in to reflow) Perform your rework or assembly operation. Clean the gel and surrounding area using DI water and a soft brush or run it through your wash machine cycle using a water only cleaning process. The gel is water soluble and harmlessto PCBs as long as it is washed off.
Dan Patten from BEST Inc. reported “We are excited about being able to bring such a dramatically effective product to market. Most clients, upon seeing it being used don’t believe how effective it is!”
The HeatShieldGel™ comes in 3 oz plastic sealed screw top jar and retails for less than $30.
About Business Electronics Soldering Technologies (BEST)
Headquartered in Rolling Meadows, Illinois BEST is a supplier of PCB rework and repair services as well as tools for those services in the communications, computer, industrial, automotive, avionic and military sectors. In addition BEST is a master IPC-certified training center certifying students and instructors in J-STD-001, IPC-610 and IPC 7711 and 7721 material.
Contact: Bob Wettermann
www.solder.net
May 12, 2019 -
Custom SRT and Hot Air Nozzles
Oct 23, 2018 -
High mix Low Volume Technical Webinar
Aug 17, 2018 -
New Product Launched Component ID Poster for Electronics Training
Jun 15, 2018 -
Capabilities Video Launched
Mar 20, 2018 -
BEST Announces Availability of Custom Electronics Packaging
Nov 25, 2017 -
FREE IPC-A-610 and J-STD-001
Oct 03, 2017 -
New Sustainable J-STD-001 Soldering Kit
Oct 03, 2017 -
Mar 31, 2017 -
BEST Inc. Puts Semi-Automated Mass PCB Rework Process Online
Oct 25, 2016 -
BEST SMT Boot Camp Nov 29-Dec 1, 2016 Featuring Phil Zarrow
24 more news from BEST Inc. »
Sep 14, 2024 -
How to Find the Best Reflow Oven for SMT in Your Industry
Sep 14, 2024 -
1769-L18ERM-BB1B MOTION Processors
Sep 14, 2024 -
ABB 1KHL016009R0001 NSK5G4AK
Sep 14, 2024 -
SIEMENS 7UT5131-5CB01-1BA0/KL
Sep 14, 2024 -
EPRO PR6424/104-141 CON041
Sep 14, 2024 -
SIEMENS 6DS1122-8AA
Sep 14, 2024 -
NISSEI BS1-N018
Sep 14, 2024 -
ABB DSMC110 57330001-N
Sep 14, 2024 -
BENTLY NEVADA 330104-00-24-10-02-00
Sep 14, 2024 -
LEUZE IFRK 93/4-100 L.2
BEST Developes Revolutionary Gel for Masking of Parts news release has been viewed 1342 times
