PROMATION Debuts IS-4000P Solder Robot @ SMTA Chicago
Aug 26, 2016
IS-4000P
IS-4000P
The IS-4000P model offers exceptional performance and value for an in-line hot iron soldering work cell and sets a new standard for fully integrated soldering robots. Constructed on a welded steel frame, the work cell boasts a 4 axis Cartesian robot, dual stop steel roller chain conveyor, Top Side Pre Heat, product Lift and Locate, 150 watt power supply (with super-fast thermal feedback loop), positive tip location, black chrome solder tips, auto solder feeder, and mesh tip cleaning station for superior soldering results. The precision Cartesian robot uses dual servos to direct the tip to the exact solder joint location every time. Soldering programs can be established quickly through the use of a detachable control pendant, high resolution witness camera and huge process viewing monitor (mounted on the front panel of the work cell). The controller can store up to 255 programs with program change-over in less than 1 minute.  Other work cell features include: Dual port fume extraction with one directly at the tip location, selectable pre heat temp and dwell time, front mounted Keyence light curtain system allow the work cell to be run with the front door slid open or closed, and the program simulation mode verifies joint positions prior to actual soldering.  In addition to superior performance, this base work cell offers customers a 1 year ROI based upon two to three shift production while improving quality and throughput.
Nov 04, 2022 -
PROMATION Awarded Best New Technology – Soldering Technologies
Jun 17, 2022 -
PROMATION's new Machine Tending Video now available
Jun 09, 2022 -
PROMATION National Sales Meeting
Jun 09, 2022 -
PANDA Soldering is HERE
Jun 09, 2022 -
TECHMAN COBOTS
Oct 14, 2021 -
IN STOCK PCB CONVEYORS
Jul 01, 2020 -
Made in the USA Face Masks
Dec 09, 2019 -
YEAR END DELIVERY PRODUCTS
Dec 09, 2019 -
PROMATION Turns 20
May 19, 2019 -
PROMATION Batch Process Depaneling
144 more news from PROMATION, Inc. »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
PROMATION Debuts IS-4000P Solder Robot @ SMTA Chicago news release has been viewed 1266 times
