The EUV-700 is a �state of the art� conveyorized UV curing station that incorporates Fusion F300 version �D� lamps. The station has a standard focal distance of 2.1� above the product which produces a 1� wide curing zone. To accommodate a wide range of component heights the lamp housings may be index in the Z direction (2.1� up to 5�) to prevent the possibility of overexposure for taller components. Each 6� long UV section is selectable through the systems Touch Screen. This energy saving feature allows operators the ability to only turn on and use the desired width range needed. Selectable width ranges are 6�, 12� and 18�.
The station is also equipped with safety side doors and a multi-stage in-line conveyor integrated into special touch panel controls. Operators can set desired cure times through a precise variable speed drive located in the center section of the station under the UV lamps. PROMATION also uses a combination of standard belting and steel transport chain (under the UV section) to provide reliable performance. Product transfers on 3 mm edge contact to fit a wide range of applications.
For more information about PROMATION�s UV Curing Station, please contact your local sales representatives, visit their web site at (www.Pro-mation-Inc.com) or contact Mr. Gary Goldberg, at (262) 942-4177
