blackDIAMOND heat sinks are 30 mm high by 64 mm wide by 89 mm long for precision mounting on Xeon processors and other CPUs used in 1U packages, including the Intel P4, and the AMD Opteron�� and Athlon�� 64. The sinks range from 144 to 162 grams in weight, making them much lighter than typical 1U heat sinks of either passive or integrated fan design.
blackDIAMOND heat sinks provide thermal resistance as low as 0.28 C/W with air velocity of 800 ft/min. They are available with or without thermal interface materials and are attached with standard mounting clips. More information on blackDIAMOND heat sinks is available from the Advanced Thermal Solutions website, http://www.qats.com, or by calling 781-769-2800.
