  • One platform – many solutions. Preview for Seica Inc for Apex 2013, San Diego, February, booth 627
Jan 30, 2013
The new COMPACT Line collects the inheritance and success of the historic line of SEICA in-circuit and functional testers, designed meeting the requirements of the so called “lean production”, with a specific attention to the requirements of the production environments of electronic boards.
With 8 electrical flying test probes (4 on each side), 2 Openfix flying probes (1 on each side) 2 power flying probes (1 on each side) and 2 CCD cameras (1 on each side), the Pilot V8 has 14 mobile resources available to test the UUT, all included in a vertical, very compact and robust architecture, making Pilot V8 unique in its genre.
Firefly is the selective soldering solution that has been developed to satisfy the ever growing need of modern electronics manufacturing for maximum flexibility, and to address the particular problems related to the introduction of the new lead-free alloys.
Seica, Inc. will be an exhibitor at the 2013 IPC APEX show being held in San Diego this year.  Visitors are welcome to booth # 627 to learn more about the industry leading ATE and functional test systems, an impressive array of the latest Seica product developments: The featured systems in booth #627 will include the Pilot V8 Flying Prober, the Firefly Laser Selective Soldering system, and the Compact TK Functional and In-Circuit Test system.
The Compact Line
Like all of Seica’s solutions, this line is based on the core software/hardware VIP platform, but is specialized for multiple applications, with specific reference to the automotive industry, and includes systems dedicated to in-circuit test, on-board programming of digital devices, functional and end-of-line board testing (EOL), with manual or fully automated UUT loading/downloading. In addition, visitors will be able to view a wide range of application solutions on the different systems, including test fixtures and programs implemented in VIVA software and  NI Labview/TestStand*, which is 100% compatible with the COMPACT systems’ hardware architecture. This is a unique opportunity for a closer look and a hands-on experience of Seica’s capabilities of specializing ATE according to the client requirements, while maintaining the compatibility of fixtures and programs across the entire system range. The Compact line is fully compliant with lean production guidelines typical of the WCM standard, widely used in different sectors of today’s global industrial production environments.
Compact TK Functional and In-Circuit system
TK is the smallest configuration of the Functional and In-Circuit systems. Voted best in World Class Manufacturing by a premier Automotive contract manufacturer, the Compact line is recommended for ICT, functional,  and on-board programming applications.  It is characterized by a high level of ergonomy, small footprint, easy maintenance, low power consumption and enhanced operator safety.  The features of the Compact TK include:
  • Small stand-alone solution
  • Parallel test option
  • Up to 1536 analog channels
  • Up to 125 hybrid channels (maximum 10 MHz digital)
  • Up to 3 user power supplies
  • Functional test expandability
  • On board programming features
  • Boundary scan test option
  • Pneumatic/vacuum fixture receiver options
  • Cabinet fully integrated with PC and receiver
The Pilot V8 is an innovative technology that offers maximum performance in regards to high test speed, test coverage and flexibility.  The system’s vertical architecture is the optimum solution for probing both sides of the UUT simultaneously.  This feature guarantees fast, precise, reliable and repeatable probing; it also allows for full availability of all the mobile resources for testing the UUT.
The Pilot V8 is equipped with 8 electrical flying test probes (4 on each side), 2 Openfix flying probes (1 on each side) and 2 CCD cameras (1 on each side), and 2 power probes (1 on each side) for a total of 14 mobile resources available to test the UUT.  The mobile power probes enable power up of the UUT without requiring any additional fixed cables, allowing easy implementation of functional test.
The test tools and techniques of the Pilot V8 include:
  • FNODE signature analysis on the nets of the UUT
  • Standard analog and digital in-circuit test
  • Vectorless tests (JSCAN and OPENFIX), to test ICs for opens and shorts
  • PWMON net analysis for power on the boards
  • Continuity test to detect open tracks on the PCB
  • Visual tests for component presence/absence and rotation
  • Optional functional test and boundary scan test capabilities
  • On Board Programming tools for digital devices
  • Optional Thermal Scan resources
Firefly Selective Soldering system
The Firefly Selective Soldering system is a laser-based technology, developed with complete automation and simplicity of use in mind.  The Firefly has been designed to optimize flexibility and automation, including solutions for specific requirements, such as an external pre-heating unit.  The Firefly is available in three configurations: top soldering, bottom soldering, along with top and bottom soldering.
The laser in the Firefly system is a clean and versatile technology.  The energy through the laser allows for point to point adjustment of the power needed for soldering; the lack of thermal inertia of the laser, combined with real-time temperature readings enables the dynamic creation of the thermal profile.  The ability to apply all of the energy in a single point makes this technology applicable in situations where it is not possible to heat the whole board or where there are problems generated by reduced accessibility.  The user is able to change from lead to lead-free solder by simply changing the spool of solder wire.  The clean soldering process eliminates the costs and logistics involved with cleaning boards and handling residual waste.
Seica S.p.A, founded in 1986, is a global supplier of automatic test equipment and selective soldering systems, with an installed base of more than 1000 systems on four different continents.  Seica offers completely automated, laser-based selective soldering solutions, as well as a complete line of test solutions, which include bed of nails and flying probe testers; which have the ability to perform manufacturing defect analysis, in-circuit tests, functional tests and optical tests of loaded boards, second and third level electronic modules and printed circuit boards. Seica S.p.A corporate headquarters is located in Italy, with offices in France, Germany, USA, and China, along with a worldwide distribution network. www.seica.com
Seica Inc., is a subsidiary of Seica SpA, with offices in Salem, New Hampshire and Plano, Texas. It is staffed with sales, engineering and field support teams to address customer needs throughout North America.
Jul 08, 2024 -
Jul 01, 2024 -
Seica to Showcase Advanced Flying Probe Test System Pilot VX at SEMICON West 2024
May 06, 2024 -
Mar 26, 2024 -
Nov 27, 2023 -
Nov 20, 2023 -
Nov 06, 2023 -
Oct 31, 2023 -
Sep 13, 2023 -
Jun 26, 2023 -
SEMICON West – July 11-13, 2023
92 more news from SEICA SpA »
Jul 19, 2024 -
Koh Young to Host SMTA Atlanta Chapter Technical Meeting on State-of-the-Art Test Techniques presented by Vaughan Carlson from VALUE Engrafting
Jul 19, 2024 -
Electronica 2024: Where Vision Meets Reality
Jul 18, 2024 -
Jul 16, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
One platform – many solutions. Preview for Seica Inc for Apex 2013, San Diego, February, booth 627 news release has been viewed 738 times
