Siborg's easy to use LCR-Reader-MPA placed third in the Product of the Year contest hosted by Plant Engineering. Subscribers voted for their favourite products of the year, with MPA in the Maintenance Tools and Equipment category.
Plant Engineering is an online and offline magazine and source of products for production and maintenance. MPA competed against products from Des-Case Corp., Exair, and 2 products from Fluke Corp. in their category.
LCR-Reader-MPA is a digital multimeter with LCR/ESR measurements, LED/Diode testing, 100 kHz test frequency, AC/DC Voltage/Current meter, Oscilloscope and more. Without any set-up the device is able to determine the type of component and best test parameters to use for LCR/ESR measurements. Users are also able to switch modes, test frequencies, etc. to customize for the specific measurement at hand.
- Automatic and manual LCR/ESR measurements
- 0.1% basic accuracy
- Test frequencies: 100, 120 Hz, 1, 10, 20, 30, 40, 50, 60, 75 and 100 kHz
- LED/Diode measurements
- AC/DC Current/Voltage True Vrms measurements
- Super Large Capaitance tests up to 1 F
- Three test signal levels: 0.1, 0.5 and 1.0 Vrms
- Signal Generator
- 1.3 oz. eight and ergonomic design
Siborg has recently begun offering a Bluetooth enabled model of MPA that provides remote measurement recording in real time. When used with the LCR-MPA-BT Data Logger Program, users can set custom profiles for components. These profiles include a set of desired values which are automatically compared to the measured values. The program then instantly determines if the measured component falls within the desired values and grants a pass or fail, marking the measured values green or red. This is an exceptional tool for component sorting and quality control. All measurement values are exportable to spreadsheet.
Siborg offers their products on their online store, the LCR-Reader store, Amazon sales channels and now on Digikey Marketplace.
