Henkel Introduces Two Encapsulants Ideal for Sensitive Components
Mar 13, 2013
Targeted, Effective Deposition and Traceability Capability with Superb Protection
Formulated to address the limitations of alternative products, Henkel Electronic Materials announces the commercial availability of two encapsulants for selective protection of environmentally-susceptible components. The materials, LOCTITE ECCOBOND UV9060F and LOCTITE ECCOBOND EN 3707F, deliver an impermeable barrier to potential environmental influences and offer manufacturers cure process flexibility and deposition traceability.
Both materials provide tough protection against the destructive effects of environmental contaminants like moisture and fluids such as beverages and perspiration.  Designed for high-UPH production environments, both LOCTITE ECCOBOND UV9060F and LOCTITE ECCOBOND EN 3707F cure quickly with UV light in less than 30 seconds and contain a subsequent cure mechanism to ensure shadowed areas not exposed to UV light are fully cured.  LOCTITE ECCOBOND UV9060F has a secondary moisture cure and a secondary thermal cure is built into LOCTITE ECCOBOND EN 3707F.
Henkel’s Dr. Brian Toleno, Director of Global Product Management for Underfills and Encapsulants, explains the significance of the materials’ selective application capability. “These materials are ideal for devices such as connectors, memory slots and components close to charger or headset connection ports,” says Dr. Toleno.  “If a manufacturer doesn’t want to conformal coat or pot the entire assembly, these materials enable targeted material deposition which means lower costs and often better protection.  Conformal coatings are effective over large areas, but do have a tendency to wick, produce opens and not cover corners or odd shapes well.  These innovative encapsulants solve those issues.”
In addition to their fast cure advantage and excellent protection, LOCTITE ECCOBOND UV9060F and LOCTITE ECCOBOND EN 3707F also have unique processability and traceability characteristics.  Both materials can be applied via non-contact dispensing or traditional needle dispensing to accommodate varying manufacturing requirements and high-UPH processes.  And, perhaps most novel is the fluorescent tracer designed into each encapsulant.  Because protective materials are often opaque, visually inspecting them is difficult.  With LOCTITE ECCOBOND UV9060F and LOCTITE ECCOBOND EN 3707F, exposure to black light illuminates the materials’ fluorescent tracers and allows operators to verify the intended coverage areas.
The ability to selectively apply, quickly cure and visually inspect are arguably significant advances in protective encapsulant technology,” notes Toleno in summary.  “These materials are perfect for any application with components or connectors that are susceptible to adverse environmental factors.
For more information about LOCTITE ECCOBOND UV9060F or LOCTITE ECCOBOND EN 3707F, log onto www.henkel.com/electronics  or call 714-368-8000.
Henkel operates worldwide with leading brands and technologies in three business areas: Laundry & Home Care, Beauty Care and Adhesive Technologies. Founded in 1876, Henkel holds globally leading market positions both in the consumer and industrial businesses with well-known brands such as Persil, Schwarzkopf and Loctite. Henkel employs about 47,000 people and reported sales of $21.13 billion and adjusted operating profit of $2.98 billion in fiscal 2012. Henkel’s preferred shares are listed in the German stock index DAX.
Mar 16, 2018 -
Henkel Develops Non-Proprietary Solder Paste Analysis Toolkit for Modern Process Complexities
Jan 31, 2018 -
Henkel to debut new materials, share expertise at IPC APEX Expo 2018
Mar 06, 2017 -
TECHNOMELT AS 8998 Masking Material Producing Measurable Gains in Efficiency, Cost Control; Recognized with Industry Award
Mar 01, 2017 -
Steven Abramovich Appointed Head of Sales, Americas for Henkel’s Electronics Business
Feb 23, 2017 -
Water Soluble, Tin-Lead Solder Paste from Henkel Enables High-Yield Results for Demanding Applications
Jan 24, 2017 -
Henkel to Showcase Broad Range of Enabling Electronic Materials at IPC APEX Expo 2017
Sep 21, 2016 -
Broad Portfolio of Henkel Enabling Technologies on Show at SMTA International 2016
May 11, 2016 -
Henkel Honors Manufacturing Representative, E-Tronix, with its Fifth North American Representative of the Year Award
May 09, 2016 -
Henkel Partners with Tekra to Expand Coverage of its Electronic Inks Business in North America
Mar 30, 2016 -
Henkel Develops Thermally Conductive Technomelt® Solution
50 more news from Henkel Electronic Materials »
Jun 28, 2024 -
Jun 26, 2024 -
Jun 25, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Henkel Introduces Two Encapsulants Ideal for Sensitive Components news release has been viewed 821 times
