  • TopLine’s Micro-coil Springs (MSC) for CCGAs in Harsh Environments Featured at IPC/APEX EXPO 2017
Jan 29, 2017
Absorbs Extreme Shock CCGA and BGA Components; Novel Interconnect Innovation
TopLine, a leading designer and manufacturer of electronic components and packaging solutions for PCB assemblies, will exhibit its MSC Series of Micro-coil springs, a novel interconnect for CCGA (Ceramic Column Grid Array) IC packages for harsh environments. In tests using daisy chain test vehicles, Micro-coil springs absorbed extreme shock of up to 50,000g before failing. Commercial applications include aerospace, avionics, military, down-hole oilfield drilling and automotive electronics. Test results were initially presented at IEEE CPMT 2012.
MSC technology and its benefits will be explained and discussed by TopLine’s President, Martin Hart, in the TopLine booth, #923, at the IPC/APEX EXPO 2017 trade show in San Diego, California February 14-16, 2017.
Engineers at NASA's Marshall Space Flight Center initially developed this novel interconnection structure for integrated circuit packages. This innovation replaces traditional CCGA solder columns with the potential to extend life under harsh environments, extreme thermal stress, vibration and shock. The Micro-coil Spring technology provides flexibility in three dimensions between the ceramic (or plastic) package and the PCB board. This technology offers a distinct improvement over cast Pb90/Sn10 solder columns or copper-ribbon-wrapped Pb80/Sn20 solder columns, which have limited flexibility under shear stress. MSC technology offers a novel alternative, providing better flexibility in high temperature and harsh environments.
Micro-coil springs are fabricated from beryllium copper C17200 (Alloy 25) per ASTM B 197. The coils are post-plated with electro-deposited Sn60/Pb40, 100 micro-inches minimum thickness. Micro-coil springs may also be used in place of solder balls on plastic PBGA packages. After reflow at normal tin-lead temperature profiles, Sn63/Pb37 solder paste forms a fillet around the double coil ends of the spring.
To learn more, visit http://www.topline.tv/CCGA_MCS_Micro_Coil_Spring.html, and visit the TopLine booth #923 at APEX.
TopLine Corporation is a leading provider of test vehicle components and packaging solutions for Circuit Assemblies. TopLine manufactures CCGA Column Grid Arrays, solder columns, and a wide range of daisy chain semiconductor packages. TopLine offers a complete range of daisy chain test chips for process development, experimentation, machine evaluation, solder training, and SMT assembly practice. TopLine products provide hands-on learning for engineers. TopLine is a one-stop source for all dummy components. For more information, contact TopLine Corporation, 95 Highway 22 W, Milledgeville, GA 31061, USA. Tel (800) 776-9888; Email: sales@TopLine.tv.
Jan 25, 2017 -
ITW EAE Introduces MPM 100 Printer to Meet Market Demand for Reduced Cost
Mar 31, 2016 -
Speedline MPM Edison Printer Takes an Impressive New Product Introduction Award at APEX 2016
Feb 24, 2016 -
Speedline Displays New Technologies at APEX 2016, MPM, Electrovert, and Camalot Products
Nov 18, 2015 -
Speedline Technologies’ MPM Edison Printer Takes Prestigious Global Technology Award at Productronica 2015
Oct 27, 2015 -
Speedline Launches MPM® Edison Next Generation Printer Platform
Aug 22, 2014 -
Speedline's Isaiah Smith to Present at SMTAI 2014; PCB Assembly Solutions also to be Exhibited.
Aug 06, 2014 -
Free PCB Cleaning and Reliability Workshop Planned Sept. 9 in Guadalajara
Jun 12, 2014 -
Speedline Launches New Electrovert® Electra™ Next Generation Wave Soldering System
Apr 30, 2014 -
Speedline Launches Space-Saving MPM® Momentum® BTB (Back to Back) Printers for Dual Lane Configuration
Oct 31, 2013 -
Speedline's MPM® Momentum® Family Printers Boast Higher Accuracy for Competitive Performance
8 more news from Speedline Technologies, Inc. »
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
TopLine’s Micro-coil Springs (MSC) for CCGAs in Harsh Environments Featured at IPC/APEX EXPO 2017 news release has been viewed 1544 times
Facility Closure
