  • SIPLACE Alternative Tracks More precision and flexibility on the SMT line
Jul 24, 2012
With Alternative Tracks, the SIPLACE team has made the setup process in electronics manufacturing even more flexible. Thanks to the new function, components can now be installed in multiple tracks of the component cart. When the first feeder runs empty, the system automatically switches to an alternate, which can be set up on any track of the component cart. The new function was designed for applications where splicing should be avoided for technical reasons or where traceability must be ensured down to the component level. Combining Alternative Tracks with the well-known Alternative Components function makes the line even more flexible.  If one component reel runs out, the job can continue running non-stop with predefined alternative components. These can now be supplied on a different width-feeder in any position on the same component cart.
The classic processing of splicing a tape to an existing reel when it is about to run empty carries significant risks for traceability and very demanding applications. With its Alternative Tracks function, SIPLACE now offers new options for such applications. When a track has run empty, the system automatically switches to a feeder and components on an alternative track. The respective feeders and components can be set up on the same component cart. Operators can set up alternative tracks in advance as part of the product setup or immediately before the primary track is about to run empty. In either case, the SIPLACE placement machine will switch to the alternative track automatically and with no production interruption.
The new functions can also be combined with the older "Alternative Components" function, i.e. the new reel doesn't have to be identical to the reel that is about to run out and can even be supplied on a different-size feeder.
Setup optimization and Random Setup tracking
Since random setups tend to increase cycle times, the SIPLACE software includes a function that lets you reorganize the optimized setup more easily. At the push of a button you can identify feeders that are not positioned optimally and move them to more efficient locations.
"With Alternative Tracks we offer another improvement in setup flexibility. The result: simplified setup processes that are faster and let you run your line as effectively and with as few interruptions as possible. The combination of all these functions demonstrates the superiority of our software. Everything is based on the idea that fast and error-tolerant setups are the key to more efficiency and consequently to the financial success of our customers," explains Hubert Egger, product marketing manager on the SIPLACE team.
Alternative tracks can be set up by operators in advance as part of the product setup or immediately before the primary track is about to run empty.
For more Information, visit www.siplace.com.
ASM Assembly Systems
At the beginning of 2011, the SIPLACE team (formerly Siemens Electronics Assembly Systems) became a business unit of ASM Pacific Technology and operates now as ASM Assembly Systems. With its SIPLACE machines and innovative manufacturing concepts, ASM Assembly Systems GmbH & Co. KG is the world’s leading manufacturer of surface mount technology (SMT) placement machines and solutions. Since its beginnings in 1985, the company has installed almost 25,000 placement machines at over 2,500 customers all over the world. Electronics manufacturers in all industries such as telecommunications, automotive, IT, consumer electronics and automation use and depend on SIPLACE's broad portfolio of solutions and services.
For more information about ASM Assembly Systems (SIPLACE), visit www.siplace.com.
As a subsidiary of ASM International, which has its headquarters in Almere, Netherlands, ASM Pacific Technology (ASMPT), Singapore, has developed in only a few years into the world’s leading supplier of chip assembly, bonding and packaging systems and solutions. The ASMPT Group produces and markets machines for front-end and back-end chip assembly and semiconductor packaging. The company has plants in Hong Kong, China, Singapore and Malaysia, and since January 1, 2011 in Germany. ASMPT has been listed on the Hong Kong Stock Exchange since 1989.
ASMPT is one of the stocks in the Hang Seng HK MidCap Index under the Hang Seng Composite Index, the Hang Seng Information Technology Industry Index, and the Hang Seng Hong Kong 35 Index.
For more information about ASMPT, visit www.asmpacific.com
Send reader inquiries to:
Susanne Oswald
Email: susanne.oswald@asmpt.com
Jul 22, 2021 -
ASM presents new products in livestream
Apr 01, 2021 -
Software for non-proprietary communication and knowledge transfer on the shop floor
Feb 12, 2021 -
Waldemar Christen named VP CRM of ASM SMT Solutions
Oct 30, 2016 -
ASM Munich is “Factory of the Year”
Aug 04, 2016 -
First ASM Roadshow in Minnesota
Jul 02, 2016 -
Successful ASM Roadshow in Manaus
May 16, 2016 -
ASM Press News: Four awards go to innovative products from ASM
May 13, 2016 -
ASM at 2016 NEPCON Shanghai - Four Awards Go To Innovative Products from ASM
Apr 07, 2016 -
APEX a great success for ASM Lots of interest in the Smart #1 SMT Factory
Dec 20, 2015 -
World's largest supplier of SMT equipment for the first time in 2015
36 more news from ASM Assembly Systems GmbH & Co. KG »
Jun 13, 2024 -
Jun 13, 2024 -
Jun 12, 2024 -
Jun 11, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
SIPLACE Alternative Tracks More precision and flexibility on the SMT line news release has been viewed 673 times
Cost-effective Conformal Coating Machine
