Manncorp P&P Assembles 4-Foot-Long LED Light Panels
Mar 28, 2011
Manncorp has rolled out its latest LED-enabled pick and place system, the MC392LED. With the optional CT-150 Conveyor Extension Unit, the machine is ideally suited for populating extra-long LED panel assemblies in a single pass. It also performs traditional SMD assembly.
The continued popularity of LEDs – most notably in automobiles, energy-conserving lighting and consumer electronics – has caused Manncorp to roll out another LED-enabled pick and place system. The MC-392LED, according to CEO Henry Mann, "has features that will win approval from traditional SMD assemblers as well as those who mount diodes."
MC-392LED is ideally suited for populating extra-long LED panel assemblies in a single pass. Through the use of the low-cost optional CT-150 Conveyor Extension Unit, the machine becomes capable of two-stage assembly of oversized LED boards of up to 1.2m (47.25”) long. "With its dual-head placement rate of 6,400 cph and long record of reliability in SMD placement, it's a certainty that the 392 will meet or exceed production goals," the CEO added. Other features include ball screw X-Y drive and closed-loop servo control with linear encoding for placement accuracy of 30µm, 3 Sigma.
The 392’s vision system is Cognex®-based for “on-the-fly” alignment of any SMD from 0.4mm x 0.2mm (01005 footprint) to 16mm x 14mm, including CSPs and µBGAs. Optional upward-looking vision cameras align components up to 150 x 100mm, including large BGAs and QFPs to 0.3.mm (0.012”) lead pitch. A vision inspection capability allows a camera to selectively check solder paste printing and component placement accuracy.
The MC392LED, at $60,000, joins the larger MC-388LED, another Manncorp LED-enabled placer with 192 tape feeder capacity, which enables it to assemble LED panels of up to 1.2m (47.25”) in a single pass without the need for a conveyor extension. It is priced at $85,000.
For details, access http://www.manncorp.com/pick-and-place/mc392led or call 1.800. PIK-MANN (745.6266) or e-mail sales@manncorp.com. Manncorp offers pick-and-place machines, stencil printers, reflow ovens, rework systems, wave solder machines, solder pastes, board cleaners, desiccant cabinets, and more. Accessing http://www.manncorp.com is an informational experience. Not only are full details and specifications provided for the 150+ products, but prices are also attainable immediately after minimal contact information is provided.
May 16, 2014 -
Improved Dip Soldering Systems Have Wider Range of Capability
Mar 25, 2014 -
Android(TM) Operating System Controls New Benchtop Reflow Oven
Jan 30, 2014 -
High-Precision, High-Mix, Print-Place-Reflow Package Under $47K
Sep 28, 2013 -
Closed-Loop, Zero-Discharge PCB Cleaning System in Operation at Manncorp DEMO Center
Jul 27, 2013 -
Manncorp Installs Selective Soldering and Fluxing Systems at Calsonic Kansei Mexicana
Jun 20, 2013 -
Manncorp Opens New Corporate & SMT DEMO Center
Jun 20, 2013 -
Dross Separator Recovers Solder and Saves Money Fast
Feb 08, 2013 -
New High-speed Pick & Place Machine for Nonstop Production of LED Boards
Oct 09, 2012 -
Manncorp Brings High-Precision, Selective Soldering and Fluxing to the Bench-Top with the New ULTIMA Series
Sep 20, 2012 -
Computer-Controlled Batch Reflow With Real-Time Profiling Mimcs Inline Reflow
39 more news from Manncorp »
Aug 09, 2024 -
Manncorp P&P Assembles 4-Foot-Long LED Light Panels news release has been viewed 1076 times
