  • Package Converters Enable Testing Generation I product on Generation II System
Nov 30, 2010
BGA Package Converter speeds system board development.
BURNSVILLE, MN - Ironwood Electronics' new package converter - PC-BGA256B/BGA256E-B-01 allow previous product version to be used in the new system boards for test/validation until the new BGA device is released from the foundry or vice versa. These package converters can be soldered directly onto the SMT pads of development boards using standard solder methods. If the BGA device also has same solder ball composition, they can be soldered simultaneously using same reflow profile along with package converter.
1.27mm pitch, 256 pin BGA old generation product can be tested on new generation PCB which has 256BGA pattern with 1mm pitch until Silicon arrival
The Ironwood Electronics package converter PC-BGA256B/BGA256E-B-01 consists of multi layer PCB with a SAC305 solder ball for SMT processing. The solder balls and PCB are RoHS compliant. Pin mapping from top to bottom footprint is 1:1. PC-BGA256B/BGA256E-B-01 is designed to receive 23x23mmBGA, 16x16 array, 1.27mm pitch on the top and converts 1:1 pin mapping to 17x17mmBGA, 16x16 array, 1mm pitch on the bottom. This allows new development system board to be tested with previous version of BGA device until the arrival of new silicon (1mm pitch BGA). This pitch convertor can be reversed by removing solder balls from 1mm pitch side and adding them on 1.27mm pitch side. By doing this, customer can test new generation BGA device (1mm pitch) on old generation system board (1.27mm pitch) for isolating new device related issues.
Pricing for the PC-BGA256B/BGA256E-B-01 is $315.00 at qty 1 with reduced pricing available depending on quantity required.
Apr 06, 2011 -
8 GHz Bandwidth Socket for Intel's ICH6 (I/O Controller Hub 6) BGA Package
Mar 22, 2011 -
Stamped Spring Pin BGA Socket for IDT's FCBGA144
Mar 11, 2011 -
Elastomer Socket for Infineon's BGA221
Feb 26, 2011 -
GHz Bandwidth Socket for Dual WLCSP
Feb 14, 2011 -
Prototype and Debug 96 ball BGA with Ease
Feb 03, 2011 -
Stamped Spring Pin BGA Socket for Burn-in Characterization
Jan 12, 2011 -
ATE Spring Pin BGA Socket for Digital Camera Processor
Dec 10, 2010 -
Spring Pin Socket for Kelvin Resistance Measurement
Nov 10, 2024 -
PEMTRON Wins Dual Awards at NEPCON Asia for Revolutionary D2 System
Nov 10, 2024 -
Accu-Assembly to Exhibit Innovative Component Storage Solutions at SMTA Space Coast Expo & Tech Forum with New Representative Kurt Whitlock Associates
Nov 10, 2024 -
SCS Expands PrecisionCure UVC (MUV) Line with Two Size Options for Enhanced UV Curing Solutions
Nov 10, 2024 -
Silicon Mountain Joins Idaho's Largest Manufacturing Event to Showcase Industry-Leading Solutions
Nov 10, 2024 -
Libra Industries Expands Powder Coating Capabilities at Guaymas Facility
Nov 10, 2024 -
Electronics Manufacturing Association Statement on U.S. Election Results
Nov 10, 2024 -
STI Recognizes Donna Taylor's 25-Year Anniversary
Nov 10, 2024 -
2024 Stromberg Student Leader Scholarship Recipient Announced
Nov 10, 2024 -
Design Guidelines for Surface Mount and Microelectronic Technology
Nov 10, 2024 -
Accu-Assembly Inc. Appoints Mike Holleran of Kurt Whitlock Associates as Florida Representative, Expanding Regional Reach and Support
Package Converters Enable Testing Generation I product on Generation II System news release has been viewed 1754 times
