Spring Pin Socket for Kelvin Resistance Measurement
Dec 10, 2010
BURNSVILLE, MN - Ironwood Electronics recently introduced a new spring pin socket addressing precise resistance measurement need for testing power management devices - SSK-QFN-7000.
Socket and Test your Fujitsu Microelectronics's DFN12NT4*3 using Kelvin Spring Probes
The contactor is a spring pin with offset plunger. This offset design allows two spring pins to contact one device lead or pad. The Kelvin spring pins have 28 gram actuation force per ball and cycle life of 500,000 insertions. The self inductance of the contactor is 0.97 nH, insertion loss
The socket is mounted using supplied hardware on the target PCB with no soldering, and uses the smallest footprint in the industry. The smallest footprint allows inductors, resistors and decoupling capacitors to be placed very close to the device for impedance tuning. To use, place QFN device into the socket, close the lid by snapping the latch and turn compression screw to apply pressure. This socket can be used for quick device characterization using Kelvin resistance measurement techniques under extreme temperature conditions.
Pricing for the SSK-QFN-7000 is $726 at qty 1 with reduced pricing available depending on quantity required.
Apr 06, 2011 -
8 GHz Bandwidth Socket for Intel's ICH6 (I/O Controller Hub 6) BGA Package
Mar 22, 2011 -
Stamped Spring Pin BGA Socket for IDT's FCBGA144
Mar 11, 2011 -
Elastomer Socket for Infineon's BGA221
Feb 26, 2011 -
GHz Bandwidth Socket for Dual WLCSP
Feb 14, 2011 -
Prototype and Debug 96 ball BGA with Ease
Feb 03, 2011 -
Stamped Spring Pin BGA Socket for Burn-in Characterization
Jan 12, 2011 -
ATE Spring Pin BGA Socket for Digital Camera Processor
Nov 30, 2010 -
Package Converters Enable Testing Generation I product on Generation II System
Sep 18, 2024 -
ABB NTCS04 infi90 CONTROLS MODULE TERMINATION UNIT
Sep 18, 2024 -
ABB SPCIS22 l/O Control Module
Sep 18, 2024 -
ABB SPDSM04 Module installation unit
Sep 18, 2024 -
ABB NTRO12-A Analog input Terminal
Sep 18, 2024 -
ABB SPDSO14 Digital output Module
Sep 18, 2024 -
ABB NTDI21-A Inverter Circuit Board PCB
Sep 18, 2024 -
ABB SPDSI22 Digital input Module
Sep 18, 2024 -
ABB SPDSI14 Analog input module
Sep 18, 2024 -
ABB NKAS01-15 infi 90 Termination Cable
Sep 18, 2024 -
ABB NTAI06 terminal board
Spring Pin Socket for Kelvin Resistance Measurement news release has been viewed 1189 times
