  • CAMI Celebrates 25 Years Developing Automation-Ready Cable and Harness Testers
Sep 13, 2018
The Production View for Pass/Fail checks. Displayed on any sized screen you desire, the color-coded graphic-rich display provides clarity and, at the click of a button, you may visualize the wiring schematically or by netlist. Components are automatically detected and displayed (including Diode orientation), wiring faults are color-coded, and full measurement data is provided for every pin-to-pin connection.
CAMI Research Inc.  (Acton, MA), manufacturer of the CableEye automation-ready cable and harness test system, is marking 25 years since its first sale and of innovating highly configurable test solutions for simple and complex multiconductor cables and harnesses. Trusted by industry leaders such as CERN, Ford, GE, Hitachi, NASA, Abbott, TESLA, Lockheed Martin, Raytheon, Airborn, Furukawa, TE Connectivity, and the Nobel prize-winning group, LIGO, thousands of test systems have shipped globally over the years.
Founder Christopher E. Strangio’s vision for CAMI Research involved developing a suite of pc-based cable testing products powered by the same intuitive software that, with the help of easy-to-interpret color-coded graphics, instantly identifies not only when there is a fault, but what type of fault and where (Fig. 1). CableEye’s highly configurable nature and automation-readiness is directly attributable to this advanced software.
Initially released for DOS in 1993 and updated regularly to work with the latest operating systems, CableEye is currently compatible with computers running all modern Windows™ operating systems. Test engineers and managers are free to choose any size monitor they require, including Touch Screens and all-in-one computers.
Of course, development of robust and modular hardware has taken major effort too, all leading towards a system that can be used automated or not, as a pass/fail check tester, or a diagnostic system at the whim of the owner.
Following release of their first product, which was a low voltage tester with fixed test connectors, CAMI switched to an industry-standard 64-pin header interface and developed easily-interchangeable, auto-detected, test interface fixtures known as connector boards. The software automatically displays a clear graphic of the connectors and wiring under test and the tester can be readily programmed to do the same for custom boards and fixtures using the PinMap™ option that was released in 1993. Connector Designer™ (2000) is an option that allows creation of custom graphics for unusual connectors (e.g. connectorized catheters) not found in the graphics library. With a single click, the wiring schematic (see photo) can be switched to a customizable netlist view. In both views, a large PASS/FAIL indicator is clearly visible. The stackable CB35 relay board, with 10 digital outputs per board, is a popular choice for those who need to manage external devices for full control and automation of the test station.
CAMI Research released its first HiPot tester, the HVX, in 2009. In 2015, the HVX-21 was launched that increased the maximum test voltage from 1500Vdc to 2100Vdc. There are now seven tester models covering low voltage and HiPot requirements, the most recent of which was released this year adding the capability of checking twist pair relationships. Guided connector assembly is a software option that was released as Autobuild™ in 2006 and which was augmented in 2008 by the release of the LightDirector™ - an accessory enabling light-guided connector assembly.
The CableEye PC-based Continuity and HiPot test system is a professional test instrument used to pass/fail check and diagnose multiconductor cables found in countless applications in Transportation, Aerospace, Energy, Appliances, Medical Devices, Defense, Robotics, Telecommunications, Scientific R&D and more. CableEye takes full advantage of the PC’s color graphic display, high-speed computation, and mass storage to provide a complete cable and wire harness management system.
Contact sales@camiresearch.com or (978) 266-2655 for a quote. Systems start at $1,295.
Note: Prices are USA only and subject to exchange rates, freight and import costs. Contact your local authorized distributor for local pricing.
Oct 23, 2023 -
CableEye Wiring Analyzers Measure 10 GΩ Isolation at 100 V
Dec 07, 2022 -
Automatically Measure and Report Environmental Test Conditions with Cable/Harness Electrical Function Data
Apr 28, 2022 -
Dec 17, 2021 -
Aug 21, 2018 -
Mar 21, 2018 -
Jan 11, 2018 -
Aug 01, 2017 -
Jul 27, 2017 -
Mar 16, 2017 -
16 more news from CAMI Research Inc. »
Aug 16, 2024 -
New Business Region
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
CAMI Celebrates 25 Years Developing Automation-Ready Cable and Harness Testers news release has been viewed 1069 times
Solder Paste Dispensing
