Cobar Solder Products to Exhibit XF3+ and 396-DRX at SMTAI 2009
Sep 18, 2009
September 2009 — The Balver Zinn Group announces that Cobar Solder Products will exhibit a complete range of advanced soldering materials ranging from bar solder to SMT solder paste to high-performance fluxes in booth 722 at the upcoming SMTA International, scheduled to take place October 6-7, 2009 at The Town and Country Resort and Convention Center in San Diego.
Cobar Solder Products also will display its XF3+ lead-free solder paste, developed to accommodate extended reflow profiles with or without the use of nitrogen. With XF3+, wetting on all common pad finishings is excellent, yielding shiny joints reminiscent of leaded solders. It also exhibits a robust printing window.
SN100C- XF3+ performs better in eliminating voiding when compared to any SAC-alloy. XF3+ paste provides improved print performance, as well as long stencil life. It also allows reflow without N2 and offers a high tack force/time.
Cobar 396-DRX, a new VOC-free flux, will be introduced at the show. This RoHS-compliant flux fulfils the need for more environmental-friendly materials, maintaining excellent soldering performance.
According to IPC-J-STD-004, the Cobar 396-DRX is classified as ORL0. It is halide and halogen free and is based on a water carrying system that provides advantages in transportation and storage conditions, and eliminates fire risks. Operators also will appreciate that it provides an odorless flux solution.
The thermally stable Cobar 396-DRX offers a wide process window with top-side preheat temperatures up to 150°C. Due to the strong thermal resistance, this flux can be used in a broad range of applications, such as high thermal mass and heavy multi-layer products that require extended and higher soldering conditions. The Cobar 396-DRX activation system eliminates bridging and provides excellent through-hole filling for lead-free as well as leaded applications.
Also available will be technical information regarding Cobar’s state-of-the art fluxes in formulations including alcohol-based, low-VOC, and VOC-free technology for use in lead-free and N2-free, SN100C-based wave and selective soldering processes.
Jan 14, 2019 -
Apr 07, 2016 -
Nov 27, 2013 -
Nov 08, 2013 -
May 28, 2013 -
Mar 11, 2013 -
Jan 16, 2013 -
Jan 04, 2013 -
Oct 03, 2012 -
Sep 26, 2012 -
77 more news from Finetech »
Aug 09, 2024 -
Cobar Solder Products to Exhibit XF3+ and 396-DRX at SMTAI 2009 news release has been viewed 856 times
