  • BPM Microsystems to Debut New Solution for In-System Device Programming at the 2012 IPC APEX Expo
Feb 03, 2012
2800ISP Semi-Automated In-System Device Programmer
2800 Universal Device Programmer
3800 Universal Device Programmer
BPM Microsystems will debut its new production solution for in-system device programming in Booth #3702 at the upcoming IPC APEX Expo, scheduled to take place February 28-March 1, 2012 at the San Diego Convention Center in California.
The new 2800ISP Semi-Automated In-System Device Programmer offers the unmatched performance and flexibility of 8th Generation site technology. With a custom-designed test fixture, operators can easily program flash, microcontrollers and other device technologies on-board after reflow.
The semi-automated design of the 2800ISP uses a pneumatic fixture with built-in safety features to actuate the pressure plate. Once actuated, the circuit board makes contact with high quality pogo pins that are specifically engineered to achieve exceptional signal integrity. Ideal for medium and high-volume production, the 2800ISP is configurable and can program up to 16 devices in parallel.
The model 2800 Universal Device Programmer uses BPM Microsystems’ cost-effective and efficient socket cards with receptacle-base socket option. Individual socket cards can be fully utilized and replaced without dramatically affecting programming capacity. With the receptacle-base socket option, customers can purchase only the consumable socket as needed. The design of BPM Microsystems’ socket cards increases manufacturing up-time, produces higher first-pass yield, and saves replacement costs by as much as 75 percent.
Ideal for mid- to high-volume production, the model 3800 Universal Device Programmer can utilize eight to 16 socket cards and is compatible with Flashstream socket cards. Integrated into the 3800 is the LaserAlign™ sensor from CyberOptics®, which assures repeatable pick-and-place accuracy and high performance during the programming process. The programmer also offers flexible options for input and output media with choices of tray, tape or tube.
The model 2800 and 3800 support microcontrollers, NAND flash, NOR flash, serial flash, managed NAND flash, EEPROM, Flash EPROM, and other technologies with densities up to an 8 Eb theoretical limit. The programmers also support devices with voltage down to 0.7 (Vdd).
Established in 1985, BPM Microsystems is a global supplier of electronic device programmers for all applications. The company is the leading supplier of vision-based automated programming systems and sets the standard in device support, performance, ease-of-use, and cost-of-ownership. The company offers a wide variety of device programmers including Universal Programmers, Concurrent Programming Systems® and Fine-Pitch Automated Programming Systems.
Aug 02, 2023 -
BPM Automated Programmer Successfully Completes CSA Certification
Jun 15, 2023 -
Adding Value through Customer-Centricity and Swift Service Resolution
Nov 12, 2019 -
BPM Microsystems Announces a Small Footprint/High Throughput Automated Programmer with 75% More Capacity
Oct 23, 2019 -
BPM Microsystems Launches Sub-$90K Automated Programming System
Sep 05, 2019 -
BPM Microsystems Continues Expansion of Global Sales Coverage with First Regional Sales Manager Based in the UK
Aug 16, 2019 -
BPM Microsystems Continues Expansion of Sales Coverage in US Market-Adds Veteran Representative, Murray Percival Company
Jun 04, 2019 -
BPM Microsystems Appoints New Chief Financial Officer
May 28, 2019 -
BPM Microsystems Announces Top Channel Partner Awards
Apr 25, 2019 -
BPM Microsystems Expands Coverage of US Market— Signs Restronics to Cover Key Territories
Apr 16, 2019 -
BPM Microsystems Launches ‘Channel First™’– a Global Channel Strategy
103 more news from BPM Microsystems, Inc. »
Jul 19, 2024 -
Koh Young to Host SMTA Atlanta Chapter Technical Meeting on State-of-the-Art Test Techniques presented by Vaughan Carlson from VALUE Engrafting
Jul 19, 2024 -
Electronica 2024: Where Vision Meets Reality
Jul 18, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
Jul 15, 2024 -
BPM Microsystems to Debut New Solution for In-System Device Programming at the 2012 IPC APEX Expo news release has been viewed 1112 times
