New and Improved GRAB EEZ Cleanroom Wipe Dispenser
Apr 20, 2021
High-Tech Conversions has released a new and improved GRAB-EEZ ESD Safe Cleanroom Wipe Dispenser.
The new GRAB EEZ will accommodate the more traditional 9” x 9” wipe size. Structural and mechanical improvements were also made to make loading wipes easier. The front cover now slides up for effortless loading. A new (optional) plastic shield can be used to cover the front window, further protecting wipes from the outside environment.
All other benefits are still in place; that is, ESD safe, four holes for optional wall mounting, easy non cross contaminating dispensing, double bagged, and ready to bring into the cleanroom.
How it Works
The GRAB-EEZ was designed with simplicity being a top priority. Typically, cleanroom wipes are supplied in flat sheets and placed on a table or in trays within a cleanroom. Because facility personnel are required to wear gloves, it is very difficult to select one wipe at a time. Consequently, sometimes three or more wipes are selected - resulting in wasteful use. The unique double C-folded cleanroom wipes, also manufactured by High-Tech Conversions are stacked inside the unit, protected from the environment until use.
The GRAB EEZ is designed to be used in a variety of controlled environments including medical, pharmaceutical, life science, laboratory, and electronics manufacturing facilities.
Each dispenser is prepared and cleaned in a cleanroom and double bagged before it is first introduced into the cleanroom where it will be used.
About High-Tech Conversions
High-Tech Conversions is a manufacturer of innovative cleaning products for controlled environments including wipes, gloves, apparel, SMT cleaning stencil wipes, and more. They produce industry leading products that are trusted by companies involved in electronics assembly, scientific research, biotechnology, and pharmaceutical industries.
For more information, contact High-Tech Conversions at 860-265-2633 or visit www.High-TechConversions.com
Aug 03, 2022 -
High-Tech Conversions Adding JNJ Industries
Feb 09, 2021 -
Reduce Cleanroom Contamination by Using High-Quality Wipes
Jul 16, 2020 -
SMT Stencil Cleaning Roll Tape Test
Apr 02, 2020 -
Manufacturer of GREEN MONSTER Stencil Rolls Celebrates 25th Anniversary
May 22, 2019 -
Get to Know Your PCB Printer Stencil Wiping Roll
May 22, 2019 -
Feb 19, 2018 -
Presaturated Surface Prep Wipe
May 16, 2017 -
High-Tech Conversions Adds New Presaturated Wipe Options
Sep 01, 2016 -
Contract Manufacturing and Private Labeling Solutions
Mar 28, 2016 -
ISO 5-6 ESD Cleanroom Wipes
33 more news from High-Tech Conversions »
Aug 14, 2024 -
Aug 14, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
Aug 12, 2024 -
New and Improved GRAB EEZ Cleanroom Wipe Dispenser news release has been viewed 567 times
