  • RMD Instruments’ LeadTracer-RoHS XRF Tests RoHS Compliance in Solar Applications
Sep 07, 2010
LeadTracer-RoHS XRF.
WATERTOWN, MA - Devoted to the development of new radiation detector and systems technology, RMD Instruments Corp. announces that its innovative LeadTracer-RoHS XRF system now can be used in solar applications to ensure RoHS compliance.
The system is a major innovation and advancement of the XRF analysis technology, and is the only XRF system designed to provide a fast, accurate and portable screening capability to meet RoHS directives.
The LeadTracer-RoHS XRF system is a RoHS compliant solution designed specifically for screening all RoHS/WEEE and common elements in electronics and solar equipment including China RoHS. The system also is a soldering analysis solution ― it is a quick, easy method to conduct daily solder pot analysis instead of waiting every three months. Finally, the system serves as a counterfeit components solution by providing a nondestructive method for component verification.
Counterfeit or substandard components are a major issue facing the electronics industry. Counterfeit suppliers are becoming more sophisticated and are using techniques such as laser etching in production of these components, making them virtually undetectable from the real parts. RMD’s LTRSync+ software feature takes advantage of the LeadTracer’s superior K-Shell X-rays that allows the user to identify parts that might be substandard.
RMD has added a new solder analysis and identification feature to its LeadTracer-RoHS XRF system that accurately identifies all solder alloys within minutes. This is helpful when completing rework or repair for finished assemblies. Additionally, this new resource accurately performs a “solder pot” analysis, allowing users to track “changes” in their process. This is especially beneficial for SAC alloys in which an increase in Cu and Pb content (due to component drag-out) can affect not only the soldering process, but also RoHS compliance status.
As a further benefit to users, the solder analysis and identification feature addresses various potential “weak links” in the production chain, especially in a dual-alloy manufacturing operation. These include boards for second-side assembly on a non-continuous line; boards taken off-line for inspection and analysis; reflow boards moving to wave or selective soldering; boards split into two batches due to line shortages; boards moving from production to rework areas; boards held for missing parts or for component recovery; components held in rework areas; and components from placement reject trays.
The LeadTracer-RoHS XRF system has a unique approach because it analyzes the entire body of the components in a short period of time, rather than simply carrying out a surface analysis. This speeds up the RoHS screening requirements and improves the overall throughput of the quality control process. The LeadTracer-RoHS’ ability to analyze the entire energy spectrum eliminates the possibility of false-negative indications in components that otherwise would have found their way into the manufacturing process.
The use of non-compatible components such as those containing lead in a lead-free process will result in contamination of the solder pot, which is costly and environmentally undesirable. Elimination of non-compatible components from the process saves time, money and leads to improvement of the line output. Additionally, the consistent flow of parts will reduce the maintenance and repair of the machinery used in electronics assembly. RoHS directives restricting the use of certain substances in electronics have created numerous challenges in both the screening and implementation process. LeadTracer-RoHS’ innovative approach with enhanced detection capabilities provides the screening tool that the industry needs to meet the numerous RoHS directive challenges.
The LeadTracer-RoHS XRF system is now available with a sample preparation stand developed with the needs of the end user in mind. The stand has been ergonomically designed for optimum ease-of-use and accuracy and is equipped with RMD Instruments exclusive “quick disconnect” grip to enable users to operate the hand-held, portable LeadTracer-RoHS as a benchtop unit.
RMD has been a designer and manufacturer of XRF and other scientific technologies since 1974. In addition to the electronics industry, RMD produces instrumentation for the medical and applied sciences industries. For more information, contact: Steve Glass, Business Development Manager, RoHS.WEEE Division, RMD Instruments, Corp., 44 Hunt St., Watertown, MA.
Dec 17, 2010 -
RMD Instruments Appoints Experienced Representative for the Pacific Northwest
Nov 02, 2010 -
RMD Instruments’ LeadTracer-RoHS with “MCA” Software Option Recognized by 2010 Global Technology Awards
Aug 27, 2010 -
RMD Instruments to Discuss How to Improve Supply Chain Reliability with XRF Technology at PCB West 2010
Mar 27, 2010 -
RMD Instruments to Highlight the Latest Feature for its LeadTracer-RoHS System at APEX 2010
Dec 07, 2009 -
RMD Instruments LeadTracer-RoHS System to Highlight New Features at Productronica
Sep 17, 2009 -
RMD Instruments to Highlight a New Feature for LeadTracer-RoHS System at SMTAI 2009
Sep 03, 2009 -
RMD Instruments’ Steve Glass Awarded Best Paper at SMTA China South 2009
Aug 28, 2009 -
RMD Instruments to Premier A New Feature for LeadTracer-RoHS System at IPC Midwest 2009
May 15, 2009 -
RMD Instruments Appoints Representative for Missouri, Kansas, Iowa, and South Illinois
May 13, 2009 -
RMD Instruments Appoints Representative for Arizona, New Mexico, Clark County Nevada, and Sonora, Mexico
18 more news from RMD Instruments »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
RMD Instruments’ LeadTracer-RoHS XRF Tests RoHS Compliance in Solar Applications news release has been viewed 1163 times
