  • SEHO at Productronica 2013: A PLUS of Innovations and a PLUS of Services
Oct 09, 2013
SEHO Systems GmbH, a worldwide leading manufacturer of automated soldering systems and customer-specific solutions, will exhibit in Hall A4, Stand #578 at the Productronica International Trade Fair in Munich, Germany. Visitors can look forward to a variety of soldering highlights and a PLUS of innovations and services. The focus is on increased efficiency and productivity in electronics manufacturing.
Time plays a key role in modern electronic production. At Productronica 2013 SEHO will introduce the new product family SelectLine, a fully modular selective soldering system. Its revolutionary design convinces with high precision and a high degree of flexibility – no change-over is required to dynamically process a variety of assemblies with short cycle times.
In the fluxing area, the new creative axis fluxer offers extra versatility. Multiple axes are used for parallel, even asymmetrical fluxing to help reduce cycle times. Its high-precision micro-drop nozzles can be programmed completely independently. And of course, different fluxes can be made available permanently to cover various process requirements without setup times. SelectLine preheating types and length can be configured individually.
The soldering area – the heart of SelectLine – also scores highly thanks to its outstanding flexibility. Several solder pots with different solder nozzles, either completely wetted or a directed solder flow to one side, can be integrated. They work in parallel and ensure maximum throughput. For small lot sizes and high mix of assemblies, different alloys can be processed without additional setup effort.  A unique feature is the possibility to integrate an AOI system for solder joint inspections directly into the system – a big plus with regard to space and handling costs.
SEHO SelectLine offers a complete hardware and software package for automatic process control. It monitors flux amounts, including the actually applied amount, provides automatic position correction and z-height correction, controls the wave height and ensures MES integration. SEHO SelectLine is available both as an individually configurable modular inline solution and as a compact stand-alone model.
A PLUS of Soldering Solutions
Specific applications, such as wave soldering with masks, require selective flux applications that wet only the points to be soldered, not the entire mask. This prevents flux from running under the mask. Also, it significantly reduces flux consumption and shortens the cleaning cycles for the masks. SEHO has developed the coordinate fluxer SelectFlux for this purpose – a high-speed system that precisely applies the flux at previously programmed points. No other assembly areas are wetted.
At Productronica, SEHO also will exhibit the PowerWave N2 Nitrogen system for wave soldering. This solution has been specially developed for medium to large series production and is designed primarily to optimize product quality and minimize production costs. With its relatively low investment costs and low consumption values, the unit offers an optimum price/performance ratio, ensuring high profitability. This is realized through its innovative tunnel concept, individual speed control for transport segments, a modular preheating concept and the advanced soldering area that facilitates sector-based soldering.
The new PowerReflow-2 completes the product range for reflow solutions. With a heating zone length of 2700 mm, it was specially designed for medium to high production volumes. Nine heating zones and an active 900 mm cooling area provide flexible temperature profile settings and perfect solder results. The integrated process gas cleaning system ensures low maintenance. Thanks to its modern control system, easy-to-program software, interfaces for integration into a fully automated production line and many additional features, the PowerReflow-2 offers exquisite soldering technology and an ideal price/performance ratio.
The PowerSelective soldering system convinces with high-precision solder results and a flexible process for mini-wave and dip applications. Depending on the production requirements, the system can either be integrated into a fully automated manufacturing line or in a lean production concept with creative handling solutions. Ergonomically designed work places with individual height adjustment for loading and unloading, inspection places, or assembly areas for additional processing of assemblies flexibly enhance the soldering system. The many features for automatic process control include the ability to integrate an AOI system for solder joint inspections directly into the process.
SEHO also will launche ViproInline, an AOI module that can be integrated flexibly into a fully automated production line after the wave or selective soldering process to check assemblies for common THT solder faults as well as missing and misplaced components. Under reproducible test conditions, this helps to make early trend statements about the production process. The obtained data contributes significantly to process optimization and helps to increase production quality.
A PLUS of Technology
SEHO's MaxiReflow HP breaks new ground. This solution provides the ideal combination of convection heat and a special pressure module to obtain nearly void-free solder joints. The MaxiReflow HP is equipped with an innovative peak area pressure chamber that enables convection to be used for heating of assemblies and features a Nitrogen atmosphere to avoid oxidation.
With non-critical assemblies, the MaxiReflow HP also can be operated without activating the pressure chamber; boards then undergo a conventional reflow process. Since the pressure chamber is integrated into the peak area, no additional space is required.
In comparison with existing technologies for the reduction of voids, the MaxiReflow HP offers several key advantages. High pressure soldering eliminates impurities around solder joints, particularly solder balls, and it can handle even critical components, such as electrolytic capacitors.
A PLUS of Services
At Productronica 2013, SEHO will introduce its new online service portal, where customers have easy access to all of the data for their systems, including user manuals, circuit diagrams and logs. With just a few clicks users can identify spare parts and send an automatic request to SEHO. This is just another benefit of the “More for You” SEHO service initiative that provides customers with a comprehensive package of services. Customers can select their own components that will benefit their individual manufacturing processes and increase profitability. They can choose from many different elements, such as staff training at SEHO Academy, machine capability studies, RoHS measurements and customized maintenance contracts.
For more information about SEHO, visit www.seho.de.
Since its foundation in 1973, SEHO has become the worldwide contact partner whenever soldering is involved. Company solutions are based on performance, flexibility, efficiency and technical progress. SEHO’s business activities and production organization are oriented according to the principles of sustained future-compatible development and production of machines. As a result, all applicable environmental standards are complied with meticulously. With its systems, the company provides customers with a sustained and resource economizing production facility. It continuously develops its technology in order to provide customers with a competitive advantage.
For more information, visit www.seho.de.
Mar 26, 2024 -
Oct 19, 2023 -
Jul 10, 2023 -
Jan 27, 2023 -
May 27, 2022 -
Dec 21, 2021 -
Nov 22, 2021 -
Oct 11, 2021 -
Mar 15, 2021 -
Feb 25, 2021 -
Free Online Seminar from SEHO and STANNOLto Discuss Water-Based Fluxes
157 more news from SEHO Systems GmbH »
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
Jun 03, 2024 -
May 30, 2024 -
May 28, 2024 -
Infrared (IR) Laser Cutting
May 28, 2024 -
May 27, 2024 -
SEHO at Productronica 2013: A PLUS of Innovations and a PLUS of Services news release has been viewed 894 times
