Higher Productivity for Manufacturing of SMD Assemblies
Apr 02, 2020
SEHO’s GoReflow-plus convection reflow soldering system represents the ideal solution for SMT productions with medium-sized volumes that attach great priority to high solder joint quality, cost-efficiency and high flexibility. The system convinces with its well-engineered concept, excellent soldering results and unbeatable price-performance-ratio.
Eight heating zones and an active heated area of 2980 mm provide maximum flexibility in temperature profiling. The GoReflow-plus is designed for soldering in ambient atmospheres and can be operated with local nitrogen inertion in the peak area, depending on the application.
A high volume of circulated process gas, that is generated with axial fans, and specially designed slot nozzles ensure a very homogeneous heat distribution over the entire transport width at simultaneously moderate gas velocities. Thus, a very good heat transfer rate is realized, allowing the set temperatures of the oven at a low level.
The programmable fan revolution speed ensures even more flexibility, resulting in perfect solder joint quality.
The GoReflow-plus is equipped with a 3-stage cooling area to cool the assemblies after the reflow process.
A flux management system (process gas cleaning) with stainless steel filter is integrated in the peak and cooling area. Residues are collected in a PE bottle and therefore easy to dispose. This system guarantees low maintenance requirements and high machine availability.
Of course, the GoReflow-plus can be integrated into a fully automated production line. The up-to-date control concept with industry PC and the option to connect to different interfaces, such as IPC-Hermes-9852 or CFX, make the GoReflow-plus ready for future applications.
Mar 26, 2024 -
Oct 19, 2023 -
Jul 10, 2023 -
Jan 27, 2023 -
May 27, 2022 -
Dec 21, 2021 -
Nov 22, 2021 -
Oct 11, 2021 -
Mar 15, 2021 -
Feb 25, 2021 -
Free Online Seminar from SEHO and STANNOLto Discuss Water-Based Fluxes
157 more news from SEHO Systems GmbH »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Higher Productivity for Manufacturing of SMD Assemblies news release has been viewed 909 times
