SEHO Systems India, a worldwide leading supplier of complete solutions for soldering processes and automated production lines, will exhibit at productronica India, scheduled to take place September 11-13, 2024 at the India Exposition Mart Limited (IEML), Greater Noida, Delhi NCR. Meet the SEHO experts in booth # H14.B49.
SEHO is continuously developing its product range to create real added value for users. At productronica India, the company will highlight the modular inline selective soldering system SelectLine-C. Many innovative ideas are integrated into the SelectLine-C and have made it one of the most successful in the SEHO portfolio.
The SelectLine-C machine concept is consistently modular thus ensuring clear cost benefits. Several modules can individually be configurated with fluxer, preheatings, soldering units, cooling modules, selective brush unit and AOI system. Thus, the SelectLine-C adapts to virtually any manufacturing requirement and if the production conditions should change it may be expanded, the configuration can be modified, or SelectLine-C modules can be shifted to different manufacturing lines at any time.
Up to 6 soldering units and more than 15 parallel workstations can be integrated in one system.
Electro-magnetic soldering units with innovative nozzles for mini-wave and multi-wave soldering processes are part of the standard machine equipment. Maximum throughput requirements are met with the Synchro mode. This intelligent software feature coordinates the soldering process with several soldering units for one assembly type in such a way that the cycle time is nearly halved without the need for significant investment. If different products are manufactured in mixed operation, the SmartSplit mode ensures automatic split of the available soldering units, thus providing maximum throughput rates.
Automatic ultrasonic cleaning of solder nozzles is another highlight in the soldering area. What previously had to be done manually and with aggressive chemicals, is automatically and environmentally friendly performed through the machine. The solder nozzle is gently cleaned and completely re-wetted.
The SelectLine-C is ideally suited for using the LongLife mini-wave solder nozzle. This nozzle type features a lifetime that is at least three times longer than that of conventional nozzles. Therefore, the annual savings potential is remarkable. Maintenance requirements for the new nozzle are significantly reduced. The LongLife solder nozzle does not need to be cleaned or re-activated throughout a complete production shift. In addition, there is no activation needed prior to production start.
Like all selective soldering systems from SEHO, the SelectLine-C provides a complete hardware and software package for 100% automated process control. The flux quantity monitoring system and gradient-controlled temperature profiles in the preheat area, automatic monitoring of the nitrogen quantity and nitrogen quality, the touchless wave height control or automatic setup control and tool measurement are only some of the monitoring functions that ensure a reliable process.
The SelectLine-C, however, has even more to offer: The machine can be equipped with a selective brush system for automatic removal of solder balls and an AOI system for automatic inspection of solder joints immediately after the soldering or brushing process. The advantages of these integrated additional processes are obvious: Safe and reliable processes on the one hand, and reduced overall production costs on the other hand.
