SEHO’s Fluxer Control Wins a 2010 NPI Award
Apr 11, 2010
Fluxer Control.
Fluxer Control.
KREUZWERTHEIM, GERMANY - SEHO Systems GmbH announces that it has been awarded an NPI Award in the category of Soldering-Wave for its Fluxer Control. The award was presented to the company during a Tuesday, April 6, 2010 ceremony that took place in the Mandalay Bay Resort & Convention Center in Las Vegas during APEX 2010.
When soldering, process precision plays a decisive role. This primarily applies to the flux application because it is always critical to verify the flux supply. Enough flux must be supplied to the assembly, achieving sufficient hole-fill to form high-quality solder joints during the subsequent soldering process.
SEHO’s new Fluxer Control not only monitors the function of the fluxer nozzle but also measures the actual fluxing quality, i.e. fine atomized spray or spray jet. The sensors used for this control function are located within an area of the wave soldering system that is not susceptible to stain.
When micro-drop jet fluxers are used for selective wave systems, the fluxer control function measures the actual flux quantity of each drop jetted by the drop jet nozzle during the fluxing process. Integrated air nozzles ensure that the sensors that measure the flux quantity are cleaned after each cycle in order to avoid sensor malfunction.
For selective wave systems, the measured quantity is compared to a reference value learned earlier. If the system detects a deviation, an error message will be initiated. Additionally, system software clearly indicates which part of the PCB has not been fluxed correctly. Thus, the real time fluxer control ensures the highest process reliability and constant process conditions without influencing the cycle time.
Premiering in 2008, the NPI Awards program is an annual celebration of product excellence in electronics surface mount assembly. Premier products based on the finest examples of creative advancement in technology are chosen by a distinguished panel of industry experts.
About SEHO Systems GmbH
Since its foundation in 1973, SEHO has become the worldwide contact partner whenever soldering is involved. Company solutions are based on performance, flexibility, efficiency and technical progress. SEHO’s business activities and production organization are oriented according to the principles of sustained future-compatible development and production of machines. As a result, all applicable environmental standards are complied with meticulously. With its systems, the company provides customers with a sustained and resource economizing production facility. It continuously develops its technology in order to provide customers with a competitive advantage. For more information, visit http://www.seho.de
Jul 15, 2024 -
Mar 26, 2024 -
Oct 19, 2023 -
Jul 10, 2023 -
Jan 27, 2023 -
May 27, 2022 -
Dec 21, 2021 -
Nov 22, 2021 -
Oct 11, 2021 -
Mar 15, 2021 -
158 more news from SEHO Systems GmbH »
Aug 09, 2024 -
SEHO’s Fluxer Control Wins a 2010 NPI Award news release has been viewed 809 times
Facility Closure
