SN100CL Minimum Thickness Guidelines
Sep 10, 2008
Currently, there are no set criteria for minimum lead free solder finish requirements. Many companies who have run this solder coating process in the tin-lead version know that thickness varies dramatically based on pad size. Furthermore, minimum coating thickness is more critical to the solderability of SN100CL more than it is to standard tin-lead finish. Combining these two facts, it is all the more important to create a new standard by pad area.
After studying literally thousands of panels and the subsequent solderability results, Saturn Electronics Corporation has established a coupon and general guidelines for this finish.
Having this coupon on the actual board / array removes the variation in acceptability measurements between the supplier and the customer by standardizing not only the location of the measurement, but also the thickness by applicable pad geometry.
Also, customers can request a gerber format of this coupon to the waste area of ther boards. Additionally, Saturn will send the suggested minimum thickness requirements resulting from the study.
Visit the SN100CL Minimum Thickness Guidelines page at: http://www.saturnelectronics.com/minimumguides.htm
If you have any further inquiries, contact Saturn Electronics Corp. to speak with an engineer regarding any further technical matters.
Mar 30, 2016 -
Saturn Electronics Corporation Supporting U of M Autonomy project
Oct 21, 2014 -
The University of Michigan Solar Car Team To Represent the Saturn Electronics at the 2014 SAE Convergence
Mar 18, 2013 -
Domestic PCB Fabricator Certifies Nine Employees as IPC Application Specialists Per IPC-A-600
Mar 16, 2011 -
Consult LED Thermal Management Expert
Nov 09, 2010 -
Via Plugging Guidelines
Sep 30, 2010 -
Yash Sutariya to Present at IPC Technology Interchange on Thermal Management: Getting the Heat Out
Sep 08, 2010 -
Via Hole Filling
Mar 05, 2010 -
New Material & Fabrication Process Improves LED PCB Thermal Conductivity
Dec 01, 2009 -
Thermal Management for LED Applications
Oct 27, 2009 -
LED MCPCBs
31 more news from Saturn Electronics Corporation »
Sep 07, 2024 -
FOXBORO FBM207B Channell Solated P0914WH
Sep 07, 2024 -
FOXBORO FBM228 P0922QS COMMUNICATION FIELDBUS MODULE
Sep 07, 2024 -
FOXBORO P0931RQ Cable
Sep 07, 2024 -
FOXBORO FBM215 CHANNEL ISOLATED 8 COMMUNICATION HART OUTPUT
Sep 07, 2024 -
FOXBORO CP40 Model
Sep 07, 2024 -
FOXBORO FBM230 P0926GU
Sep 07, 2024 -
FOXBORO P0916VC
Sep 07, 2024 -
FOXBORO AD916AG
Sep 07, 2024 -
FOXBORO P0904BS P0904BS-0E
Sep 07, 2024 -
FOXBORO PO177VS
SN100CL Minimum Thickness Guidelines news release has been viewed 770 times
