PCB Production
Feb 16, 2009
High Volume PCB Production
Saturn Electronics Corporation, bare printed circuit board manufacturer, comprehensively maintains the entire PCB platform by isolating each part of the process into succinct stages that ensure the highest levels of quality. This rigid isolation accumulates into greater flexibility for the overall process, as well as paves the way for Saturn to set Industry criteria through its participation in ground-breaking research.
Global Manufacturing
With factories in North America and Asia, SEC produces your products in the appropriate facility based on technology and volume. The size and scale of our manufacturing facilities allow us to meet the demands of large-scale commercial production. The capabilities in all of our facilities blend to provide complete lifecycle support.
Domestic Manufacturing
Saturn has a complete manufacturing facility at Romulus MI. with TS16949 Automotive Qualification. Saturn does First Article inspection on all new lots. Saturn will inventory up to 4weeks at Romulus MI. Saturn does pre-engineering on all boards prior to sending offshore for manufacturing and panelization if required. Saturn will manufacture your board if you have a quality issue at the same cost as offshore and deliver on time to support your production. Saturn has its own team off-shore that supervises orders at the manufacturing level.
Click here for more information on Saturn Electronics Corporation, bare printed circuit board manufacturer: http://www.saturnelectronics.com
Mar 30, 2016 -
Saturn Electronics Corporation Supporting U of M Autonomy project
Oct 21, 2014 -
The University of Michigan Solar Car Team To Represent the Saturn Electronics at the 2014 SAE Convergence
Mar 18, 2013 -
Domestic PCB Fabricator Certifies Nine Employees as IPC Application Specialists Per IPC-A-600
Mar 16, 2011 -
Consult LED Thermal Management Expert
Nov 09, 2010 -
Via Plugging Guidelines
Sep 30, 2010 -
Yash Sutariya to Present at IPC Technology Interchange on Thermal Management: Getting the Heat Out
Sep 08, 2010 -
Via Hole Filling
Mar 05, 2010 -
New Material & Fabrication Process Improves LED PCB Thermal Conductivity
Dec 01, 2009 -
Thermal Management for LED Applications
Oct 27, 2009 -
LED MCPCBs
31 more news from Saturn Electronics Corporation »
Aug 09, 2024 -
PCB Production news release has been viewed 929 times
