PCB Manufacturing
Feb 17, 2009
PCB Manufacturing
Printed Circuit Board Fabrication
Top 50 PCB Manufacturer
Saturn Electronics Corporation, bare printed circuit board manufacturer, is one of the Top 50 PCB manufacturers in the United States. Established in 1985, our PCB Manufacturing facility is located in Romulus, Michigan. Saturn, the bare PCB board manufacturer, is not to be confused with other Saturns throughout the PCB supply chain who specialize in PCB assembly and Printed Circuit Board design.
Prototype PCB and PCB Production
Rigid Board Production
Saturn Electronics Corporation concentrates on high-volume PCB production while maintaining the necessary nuance for the flexibility that complex prototype boards demand. The compelling Saturn utilizes the latest PCB manufacturing equipment to oblige preliminary prototype PCB fundamentals. The laser drill and plasma equipment are complimented by the latest PCB fabrication inspection equipment for close-tolerance boards up to 24 layers.
Flexible Prototype Fabrication
By offering Prototype PCB in conjunction with High-Volume PCB Production in a reliable capacity to the PCB supply chain. In 2007, we handled numerous complex quick-turn PCB prototypes that other PCB board houses wouldn't touch. We relished the challenge and capitalized on the opportunity to reinvest into additional PCB fabrication lines to keep PCB Manufacturing capacity at 65%where Saturn and its 170 employees can remain flexible for our customers' increasing need for PCB prototypes. Saturn's reliable base of high-volume PCB production and PCB board manufacturing knowledge mixed with our knack for complex PCB prototype services separates us from other PCB manufacturers.
http://www.saturnelectronics.com
Mar 30, 2016 -
Saturn Electronics Corporation Supporting U of M Autonomy project
Oct 21, 2014 -
The University of Michigan Solar Car Team To Represent the Saturn Electronics at the 2014 SAE Convergence
Mar 18, 2013 -
Domestic PCB Fabricator Certifies Nine Employees as IPC Application Specialists Per IPC-A-600
Mar 16, 2011 -
Consult LED Thermal Management Expert
Nov 09, 2010 -
Via Plugging Guidelines
Sep 30, 2010 -
Yash Sutariya to Present at IPC Technology Interchange on Thermal Management: Getting the Heat Out
Sep 08, 2010 -
Via Hole Filling
Mar 05, 2010 -
New Material & Fabrication Process Improves LED PCB Thermal Conductivity
Dec 01, 2009 -
Thermal Management for LED Applications
Oct 27, 2009 -
LED MCPCBs
31 more news from Saturn Electronics Corporation »
Aug 09, 2024 -
PCB Manufacturing news release has been viewed 680 times
