Via Plugging Guidelines
Nov 09, 2010
With IPC-4761 as its guide, PCB Manufacturer sheds light on Via Plugging from the fabrication perspective.
IPC-4761 reflects IPC's work towards standardizing the via plugging process. To summarize, this document classifies 7 different types of via plugs. Two of these are dedicated to the use of dry film soldermask, which now has only limited usage and applications. From what we know, this usage is primarily limited to older military applications. The remainder, we would separate between via plugging and Via-in-Pad as thse two types of via plugs serve very different purposes.
Historically, and even continuing to today, the requirement for via plugging in designs has simply been called out as "via must be plugged", with some diligent designers calling out that they must be plugged with an epoxy. Overall, this is a very ambiguous callout that IPC-4761 serves to lend discipline and clarity to.
Read the rest of this technical article here: http://www.saturnelectronics.com/via-plugging.htm
Mar 30, 2016 -
Saturn Electronics Corporation Supporting U of M Autonomy project
Oct 21, 2014 -
The University of Michigan Solar Car Team To Represent the Saturn Electronics at the 2014 SAE Convergence
Mar 18, 2013 -
Domestic PCB Fabricator Certifies Nine Employees as IPC Application Specialists Per IPC-A-600
Mar 16, 2011 -
Consult LED Thermal Management Expert
Sep 30, 2010 -
Yash Sutariya to Present at IPC Technology Interchange on Thermal Management: Getting the Heat Out
Sep 08, 2010 -
Via Hole Filling
Mar 05, 2010 -
New Material & Fabrication Process Improves LED PCB Thermal Conductivity
Dec 01, 2009 -
Thermal Management for LED Applications
Oct 27, 2009 -
LED MCPCBs
Aug 11, 2009 -
Board Shops See Increased Demand for ITAR & AS9100 PCB Fabrication Capabilities
31 more news from Saturn Electronics Corporation »
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
Via Plugging Guidelines news release has been viewed 1375 times
