Count On Tools Inc. Unveils StripFeeder Mini System
Jan 21, 2015
StripFeeder Mini System.
Count On Tools Inc. (COT), a leading provider of precision components and SMT spare parts, has launched the next version of its award-winning StripFeeder System for loading tape-and-reel components onto compact modules for prototyping and high-mix, low-volume applications. The StripFeeder Mini features the same award-winning design of the original StripFeeder in a smaller, compact package (134mm x 152mm). This package is ideally suited for smaller prototype and rework machines as well as most SMT pick-and-place equipment.
The StripFeeder Mini’s compact design is better equipped to handle short strips of components, such as 2-4" of tape for both prototyping and low-volume, high-mix applications. It offers increased lane capacity with the ability to run two StripFeeder Minis in the same space as one original StripFeeder. The Mini is a lower cost option than OEM feeders, both standard and custom.
Additionally, the StripFeeder Mini features removable rails that can be mounted to accommodate a wide array of tape sizes in the same feeder. Unlike fixed width feeders, the StripFeeder Mini can be adjusted by removing the rails and re-positioning them on the base plate at the desired width (4mm pitched pattern). The rails align with precision pin locaters and lock down tightly with magnets to guarantee a stable, repeatable application.
The StripFeeder Mini rails also feature a mechanical lock-spring to hold the tape in place by the sprocket hole for part registration and repeatable pick-and-place applications. This means the user only has to teach the pick-up location one time and consistently reload the unit with the same parts over and over for longer runs.
The innovative design holds the components securely in the machined tracks to prevent parts from being miss-picked, flipped in the pocket or lost. Customers also can remove rails to accommodate larger components up to 120mm tape width. The StripFeeder Mini system is compatible with most types of SMT equipment.
The StripFeeder systems are a cost effective way to load many components, including odd-form and custom components, without having to purchase expensive feeders. The quick-to-assemble, easy-to-install modules are designed for rapid loading of tape-and-reel components on existing SMT pick-and-place equipment. Additionally, the trays enable fast changeover between product runs without unloading from the machine.
The StripFeeder trays are compatible with both paper and emboss tape simultaneously, and are ideal for low-volume high-mix applications and prototyping. For more information about Count On Tools’ new StripFeeder Mini, visit www.cotinc.com.
Sep 16, 2024 -
Count On Tools Receives Mexico Technology Awards for SMT Nozzles
Aug 26, 2024 -
Count On Tools Introduces the Innovative ezCLIP System for PCB Magazine Racks
Aug 19, 2024 -
Count On Tools Appoints Victor Madero of SMTVYS Technology as New Partner and Distributor for Mexico
Mar 18, 2024 -
Jan 29, 2024 -
Oct 16, 2023 -
Sep 11, 2023 -
Aug 14, 2023 -
Jul 31, 2023 -
Mar 16, 2023 -
221 more news from Count On Tools, Inc. »
Oct 15, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Count On Tools Inc. Unveils StripFeeder Mini System news release has been viewed 1168 times
