  • Christopher Associates' Jasbir Bath to Chair Reflow Assembly Session at IPC APEX EXPO
Mar 14, 2011
Jasbir Bath, a Consulting Engineer for Christopher Associates.
Christopher Associates announces that Jasbir Bath, Consulting Engineer, will Chair the session titled "Reflow Assembly" at the upcoming IPC APEX EXPO, scheduled to take place April 12-14, 2011 at the Mandalay Bay Resort & Convention Center in Las Vegas. The session will take place Tuesday, April 12, 2011 from 1:30-3 p.m.
Although many have predicted the demise of through-hole components, they still play a part for the assembly of many electronics products. In most cases, these components are assembled by wave soldering. However, in many mixed product technology (i.e. SMT and through-hole on the same board) products, it is a consideration to assemble the through-hole components with the PiP (Pin-in-Paste) process of soldering pin through-hole (PTH) components with solder paste that has been printed at the PTH locations followed by component insertion and reflow.
PiP has been successfully used for many years; however, in many cases it is not possible to print enough solder paste to obtain an acceptable solder joint after reflow especially on thicker boards.
This session will look at the assembly of PTH components on 130 mil (3.3 mm) thick boards using tin-lead and lead-free solder paste and solder performs to give good board hole-fill. The session will provide process engineers with comprehensive guidelines for implementing PiP technology with the addition of solder performs.
Apr 10, 2012 -
Christopher Associates to Exhibit the MAGNUS HD TREND at the SMTA Toronto Expo & Tech Forum
Apr 02, 2012 -
Christopher Associates to Exhibit the MAGNUS HD TREND at the Del Mar Show
Mar 16, 2012 -
See Christopher Associates’ Award-Winning MAGNUS HD TREND at IMAPS New England
Mar 13, 2012 -
Christopher Associates Has the Golden Ticket! Gives “Advertising Grants” at IPC APEX 2012
Mar 05, 2012 -
Christopher Associates Accepts 2012 NPI Award for the MAGNUS HD TREND from Tagarno
Feb 22, 2012 -
Christopher Associates to Introduce Leading-Edge SPI at the 2012 IPC APEX EXPO
Feb 03, 2012 -
Christopher Associates to Display High-Magnification Tagarno Magnus HD Trend at Both SMTA Dallas and Houston 2012
Jan 30, 2012 -
Christopher Associates' Jasbir Bath to Moderate Solder Joint Testing and Performance Meeting at IPC APEX 2012
Jan 26, 2012 -
Christopher Associates' Jasbir Bath to Present on Lead-free Alloys at IPC APEX 2012
Jan 21, 2012 -
Christopher Associates to Unveil New SPI Unit at the 2012 IPC APEX Expo
92 more news from Christopher Associates Inc. »
Sep 13, 2024 -
RELIANCE 57C405-E
Sep 13, 2024 -
HMS ABC-PDP AB7000-B
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
YOKOGAWA S9400UK
Sep 13, 2024 -
Sep 13, 2024 -
Sep 13, 2024 -
ABB DTDX707A 61430001-WG
Sep 13, 2024 -
GE IC220STR001
Sep 13, 2024 -
Christopher Associates' Jasbir Bath to Chair Reflow Assembly Session at IPC APEX EXPO news release has been viewed 1004 times
