Features as follows:
1. Graphic user interface is easy to use.
2. Easy to use for beginner of setting satellite dish. It can calculate Azimuth, Elevation and Polarization automatically according to local longitude and latitude and show in a graphic way.
3. It can communicate with PC through serial port. Update new satellite parameters conveniently.
4. Large memory capacity can pre-store 80 of the satellite!sparameters and measurement records.
5. spectrum analyzer function.(SF3000S)
Technical Data
1. Input Frequency
Frequency range: 950~2150MHz
2. Signal Measure
Level range: -65dBm ~ -25dBm
Input resistance: 75
Symbol rate: 2Msps ~ 45 Msps
3. Other
Dimension: 250120
Net weight: 0.8Kg
Gross weight: 1.6Kg
Working temperature:0 ~ +40
Display: 128wide-range temperature liquid crystal
display.
Audio output: build-in speaker
Port: USB (default)
Switch: 22 KHz support
4. Power Supply
LNB power supply: ��H�� +18V����500mA����V�� +13V����500mA
DC power supply: DC8.4V chargeable battery : AC110V/60Hz/220V/50Hz10%
Power adapter output: 10.4VDC 1000mA
Working time: working hours 3~4 hours (full charge)
Charging time: more than 4 hoursless than 5 hours.
5. Accessories
Common power supply adapter or Cigarette lighter adapter
1 piece (Note:Adapter is optional.)
RF input connector GMHF-L3/8-JK 1 piece
Instrument bag 1 piece
Operator!��s manua 1 piece
CD-ROM 1piece
Data cable 1piece
snowwhite
tjjsx@hotmail.com
tjjsx@163.com
008613102205839
