  • New SELECT Synchro selective soldering system increases throughput and flexibility while reducing footprint and cost-of-ownership
Feb 09, 2024
The new Nordson SELECT Synchro™ Selective Soldering system uses synchronous motion to increase throughput and flexibility while reducing footprint and cost-of-ownership for high-volume printed circuit board assembly applications in electronics manufacturing.
Key benefits of SELECT Synchro:
  • Increased Throughput – Eliminates board conveyance time by as much as 25% while delivering outstanding solder joint reliability, boosting throughput 20-40% for most applications.
  • Improved Cost-of-Ownership – The space-efficient system is as much as 4X shorter than typical selective soldering equipment, resulting in 60% reduction in footprint.
  • Smart – Automatically balances the process to broaden flux and soldering flexibility, increasing throughput while providing traceability.
  • Flexible – Configured with five solder pots to match manufacturing needs for different alloys, and different or singular nozzles. Handles long boards up to 460mm wide and 2500mm long in the standard model and boards up to 680 x 2500mm in the Synchro XL model.
  • Enhanced Quality – Improved process controls are available for closed-loop wave height check and automatic adjustment, fluxing process controls, process camera for viewing nozzles, and board warpage control.
How it works: Inside the innovative SELECT Synchro system, a board is pulled at a constant speed through the fluxing, pre-heating, and soldering process steps. The flux and solder applicators are programmed to follow and treat boards as they travel through the equipment to deliver synchronous-motion selective soldering. Multiple solder pots and different nozzle sizes are available to provide flexibility with solder quantities, solder alloys, and board designs.
“People are amazed by the technology of synchronous soldering. By moving the target board as well as the flux and soldering applicators, the operations are sped up, and the system is reduced in size," explained Florian Strohmayer, product line manager, Nordson Electronics Solutions. "In terms of throughput, the SELECT Synchro concept can replace wave soldering equipment while increasing the soldering quality and reducing the cost of ownership.”
The unique design inside the SELECT Synchro system increases throughput by reducing the time spent conveying boards as much as 25%. Multiple solder pots can be configured, and the system balances the whole process for efficiency and flexibility to deliver superior solder joint reliability. In addition, the machine’s size can be as much as four times shorter than a typical selective soldering system, for example, shrinking in length from 10 to 2.5 meters. Cost-of-ownership is improved while still accommodating long boards as large as 680 x 2500 mm.
May 17, 2024 -
Nordson Electronics Solutions expands the SELECT® Synchro™ selective soldering equipment family with new Synchro 3 release
Sep 14, 2024 -
1769-L18ERM-BB1B MOTION Processors
Sep 14, 2024 -
ABB 1KHL016009R0001 NSK5G4AK
Sep 14, 2024 -
SIEMENS 7UT5131-5CB01-1BA0/KL
Sep 14, 2024 -
EPRO PR6424/104-141 CON041
Sep 14, 2024 -
SIEMENS 6DS1122-8AA
Sep 14, 2024 -
NISSEI BS1-N018
Sep 14, 2024 -
ABB DSMC110 57330001-N
Sep 14, 2024 -
BENTLY NEVADA 330104-00-24-10-02-00
Sep 14, 2024 -
LEUZE IFRK 93/4-100 L.2
Sep 14, 2024 -
BENTLY NEVADA 133396-01
New SELECT Synchro selective soldering system increases throughput and flexibility while reducing footprint and cost-of-ownership news release has been viewed 140 times
