Techcon Systems, a product group of OK International and a leading provider of fluid dispensing systems and products, will showcase its precision valves in Booth #1641 at the upcoming IPC APEX Expo, scheduled to take place February 28 - March 1, 2012 at the San Diego Convention Center in California.
Techcon’s entry-level TS250 is ideal for general dispensing applications, and the TS350 is capable of dispensing a wide range of fluid viscosities. Both are immediately usable anywhere in the world with its accompanying tools, accessories and universal power supply.
Also on display, the TS7000IMP uses a feed screw (auger) to dispense fluid with a rotary displacement action, allowing ultra-precise control of the dispensing process. The valve’s modular design allows quick and easy replacement of the feed screw/chamber cartridge assembly without the need to remove the valve from the machine. Additionally, the valve housing is interchangeable to be used with TS5000DMP feed screw inserts.
The TS5000DMP dispenses material with a rotary displacement action using a rotary feed screw principle. The disposable feed screw inserts are replaced without the need to remove the valve from the machine. During operation, air pressure pushes the material from the syringe into the feed screw chamber. As the feed screw rotates, the material travels between the threads and out of the dispense tip. The feed screw is driven by the DC motor.
Techcon System’s 700 Series dispensing syringe barrels are silicone and chloride-free and designed to work with industry standard equipment. The syringe barrels are made from low friction polypropylene to ensure accuracy, repeatability and productivity.
Featured 700 Series consumables include the receiver head assembly, end caps, air powered pistons, syringes, syringe assembly kits, and tip caps double helix thread. Dispensing tip options include the TE Series Tips, TE Series Bent Tips, TT Tips, TS-P Plastic Tips, and Brush Tips.
The TE Series Dispensing Tips consist of a stainless steel cannula with a double helix polypropylene hub for secure syringe barrel attachment. This premier line of dispensing tips is burr-free, and has an electro-polished cannula for unobstructed and consistent material flow. Additionally, the tips are silicone and chloride-free. Maximum operating pressure is100psi (6.9bar).
For more information about Techcon Systems’ fluid dispensing systems or products, stop by Booth #1641 at the show or visit www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in the UK. Today, Techcon represents OK International’s Industrial Product Division. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping to improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves.
