  • Get a Sneak Preview of Techcon Systems’ New TS9200D Series Jet Tech at MD&M West Booth #413
Jan 29, 2013
 Techcon Systems, a product group of OK International and a leading provider of fluid dispensing systems and products, will give a preview of the soon-to-be released TS9200D Series Jet Tech valve in Booth #413 at the upcoming Medical Design & Manufacturing (MD&M) West Exposition, scheduled to take place February 12-14, 2013 at the Anaheim Convention Center in Anaheim, CA.
The TS9200D Series Jet Tech Valve is unlike any other jet valve on the market. The jet valve has a unique diaphragm design. A single, easily replaceable diaphragm eliminates dynamic fluid seals found in other jets. No longer will you have to disassemble, clean and replace worn seals, saving time and money. The diaphragm design also allows faster cycle rates due to the very small mass of the diaphragm. This unique design reduces the energy needed to eject a drop and can be adjusted providing you with wider process window.
Techcon will launch the new TS9200D in early March. Additionally, the company will showcase the following products at the show:
The TS5000 DMP and TS7000 IMP Series Auger Valves dispenses material with a rotary displacement action using a rotary feed screw principle. During operation, air pressure pushes the material from the syringe into the feed screw chamber. As the feed screw rotates, the material travels between the threads and out of the dispense tip. The feed screw is driven by the DC motor. The TS5000 DMP Auger Valves incorporate a “Disposable Material Path” for single and plural component materials with short cure times and TS7000 IMP Auger Valves incorporate a “Interchangeable Material Path” that allows for quick and easy replacement of the auger screw.
The TS5540 Series Spray Valves are designed for precise spray applications of low viscosity materials. The TS5540-MS Microshot Spray Valve is designed to spray low viscosity materials through disposable dispensing tips. Spray patterns range from 0.18"-0.60" in diameter.
Techcon System’s 700 Series dispensing syringe barrels are silicone and chloride-free and designed to work with industry standard equipment. The syringe barrels are made from low friction polypropylene to ensure accuracy, repeatability and productivity. The 700 Series consumables include the receiver head assembly, end caps, air powered pistons, syringes, syringe assembly kits, and tip caps with double helix thread.
Dispensing tip options include the TE Series Tips, TE Series Bent Tips, TT Tips, TS-P Plastic Tips, and Brush Tips. The TE Series Dispensing Tips consist of a stainless steel cannula with a double helix polypropylene hub for secure syringe barrel attachment. This premier line of dispensing tips is burr-free, and has an electro-polished cannula for unobstructed and consistent material flow. Additionally, the tips are silicone and chloride-free.
For more information, please contact the Techcon Systems team at (714) 230-2398 or visit www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in the UK. Today, Techcon represents OK International’s Industrial Product Division. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping to improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves. For more information, visit the company at www.techconsystems.com.
Dec 18, 2023 -
Techcon Launches New Extra-Large Syringe Barrel, TS60C-LL-N
Mar 21, 2022 -
Techcon is pleased to announce the launch of their new TS9800 Series Jet Valve Dispensing System, the fastest dispensing system available.
Jan 29, 2020 -
Get Smarter Dispensing from Techcon at MD&M West
Jan 16, 2020 -
Techcon to Demo New Jet Valve Dispensing System at APEX
Nov 04, 2019 -
Techcon to Demo New Jet Valve Dispensing System at productronica
Oct 21, 2019 -
Techcon introduces the TS9800 Series Jet Valve for improved speed and productivity in electronics manufacturing
Oct 18, 2019 -
Techcon to Demo Smart Dispensing Robots at The ASSEMBLY Show
Aug 22, 2019 -
Techcon Releases Dispenser for Hassle-free Dispensing of 50ml Dual Syringes
Aug 13, 2019 -
Techcon Demonstrates Smart Dispensing Robots at NEPCON Asia
Mar 18, 2019 -
Techcon to Demo Smart Dispensing Robots at productronica China
109 more news from Techcon Systems »
Aug 09, 2024 -
Get a Sneak Preview of Techcon Systems’ New TS9200D Series Jet Tech at MD&M West Booth #413 news release has been viewed 961 times
