  • Techcon Systems to Demonstrate New TS9000 Series Jet Tech Valve at NEPCON China 2013
Mar 25, 2013
 Techcon Systems, a product group of OK International and a leading provider of fluid dispensing systems and products, will exhibit in booth 1E41 NEPCON China 2013, scheduled to take place April 23-25, 2013 at the Shanghai World EXPO Exhibition & Convention Center.
The following products will be showcased at the show:
The TS9000 Series Jet Tech Non-Contact Valve is Piezoelectric driven and capable of handling fluid viscosities up to 2 million Cps.  Jet Tech offers a fast jetting action that produces hundreds of accurate deposits in less than one second.
Every component of the valve is designed to the highest tolerances and manufactured to the strictest degree of precision, ensuring world-class accuracy and repeatability in drop-to-drop dispensing volume. Special features of the valve include fully adjustable parameter settings, allowing the operator to change the jetting properties for different fluid types and optimize the process for repeatable dispensing.
The TS5000DMP and TS7000IMP Series Auger Valves dispense material with a rotary displacement action using a rotary feed screw principle. During operation, air pressure pushes the material from the syringe into the feed screw chamber. As the feed screw rotates, the material travels between the threads and out of the dispense tip. The feed screw is driven by the DC motor. The TS5000DMP Auger Valves incorporate a “Disposable Material Path” for single and plural component materials with short cure times and TS7000 IMP Auger Valves incorporate a “Interchangeable Material Path” that allows for quick and easy replacement of the auger screw.
The TS5540 Series Spray Valves are designed for precise spray applications of low viscosity materials. The TS5540-MS Microshot Spray Valve is designed to spray low viscosity materials through disposable dispensing tips. Spray patterns range from 0.18” to 0.60” in diameter.
The TS5620 Diaphragm Valves Series is designed to dispense low to medium viscosity materials with precision accuracy over a wide range of shot and bead sizes down to a fraction of a micro liter. An internal spring return makes the valves fully adaptable for use with Techcon Systems time/pressure controllers. A short opening stroke provides extremely fast, positive shut-off. An external stroke control adjustment makes it easy for the operator to fine tune shot sizes. The compact design allows for mounting flexibility and easy integration into automated applications.
Techcon System’s 700 Series dispensing syringe barrels are silicone and chloride-free and designed to work with industry standard equipment.  The syringe barrels are made from low friction polypropylene to ensure accuracy, repeatability and productivity.  The 700 Series consumables include the receiver head assembly, end caps, air powered pistons, syringes, syringe assembly kits, and tip caps with double helix thread.
Dispensing tip options include the TE Series Tips, TE Series Bent Tips, TT Tips, TS-P Plastic Tips, and Brush Tips. The TE Series Dispensing Tips consist of a stainless steel cannula with a double helix polypropylene hub for secure syringe barrel attachment. This premier line of dispensing tips is burr-free, and has an electro-polished cannula for unobstructed and consistent material flow. Additionally, the tips are silicone and chloride-free.
For more information, please contact the Techcon Systems team at (714) 230-2398 or visit www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in the UK. Today, Techcon represents OK International’s Industrial Product Division. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping to improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves. For more information, visit the company at www.techconsystems.com.
Dec 18, 2023 -
Techcon Launches New Extra-Large Syringe Barrel, TS60C-LL-N
Mar 21, 2022 -
Techcon is pleased to announce the launch of their new TS9800 Series Jet Valve Dispensing System, the fastest dispensing system available.
Jan 29, 2020 -
Get Smarter Dispensing from Techcon at MD&M West
Jan 16, 2020 -
Techcon to Demo New Jet Valve Dispensing System at APEX
Nov 04, 2019 -
Techcon to Demo New Jet Valve Dispensing System at productronica
Oct 21, 2019 -
Techcon introduces the TS9800 Series Jet Valve for improved speed and productivity in electronics manufacturing
Oct 18, 2019 -
Techcon to Demo Smart Dispensing Robots at The ASSEMBLY Show
Aug 22, 2019 -
Techcon Releases Dispenser for Hassle-free Dispensing of 50ml Dual Syringes
Aug 13, 2019 -
Techcon Demonstrates Smart Dispensing Robots at NEPCON Asia
Mar 18, 2019 -
Techcon to Demo Smart Dispensing Robots at productronica China
109 more news from Techcon Systems »
Aug 21, 2024 -
Aug 20, 2024 -
Aug 20, 2024 -
Aug 20, 2024 -
Nepcon Vietnam 2024
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Aug 19, 2024 -
Techcon Systems to Demonstrate New TS9000 Series Jet Tech Valve at NEPCON China 2013 news release has been viewed 1110 times
