Jetting Into the Future: Techcon Brings Jet Tech Valve to APEX
Feb 17, 2014
Techcon Systems, a product group of OK International and a leading provider of fluid dispensing systems and products, will showcase the TS9200 Series Jet Tech valve in Booth #2225 at the IPC APEX Expo, scheduled to take place March 25-27, 2014 at the Mandalay Bay Resort & Convention Center in Las Vegas, Nevada. Company representatives will demonstrate the following products at the event:
The TS9200D Jet Tech is a non-contact dispense valve capable of jetting fluid viscosities to 400,000 Cps. Jet Tech offers a fast jetting action producing hundreds of precise droplets in less than one second. The main feature of the valve is a single, easily replaceable diaphragm to eliminate dynamic fluid seals found in other jet valves. No longer is it necessary to disassemble, clean and replace worn seals, which translates into saving time and money. The diaphragm also allows fast cycle rates because of its very small mass. There is no large sliding valve stem that slows down the process. With this novel diaphragm design, the energy needed to eject a drop can be adjusted providing a wider process window.
Also at the show, Techcon will showcase its new TSR Bench Top Robot Series that has been designed for a wide range of fluid dispensing applications, from inline to batch. Three models are available (TSR2201, TSR2301 and TSR2401) to accommodate a wide range of working envelopes. The easy-to-program robot features dedicated fluid dispensing software, eliminating the need for complex robot language programming. With fully integrated positioning and fluid dispensing functions, the system is compatible with all Techcon Systems syringes, valves and jet dispensing systems.
The TS7000 IMP Series Auger Valves dispense material with a rotary displacement action using a rotary feed screw principle. During operation, air pressure pushes the material from the syringe into the feed screw chamber. As the feed screw rotates, the material travels between the threads and out of the dispense tip. The feed screw is driven by the DC motor. TS7000 IMP incorporates an “Interchangeable Material Path” that allows for quick and easy replacement of the auger screw.
High quality consumable products include: 700 Series syringe and components, which are made from low friction polypropylene to ensure accuracy, repeatability and productivity; and dispensing tips options, which include the TE Series Tips, TE Series Bent Tips, TT Tips, TS-P Plastic Tips, and Brush Tips. Cartridges are available in 2 ½, 6, 8, 12, and 20 oz. as well as 1/10 gallon capacities. Each size can be used with handheld or bench mounted air powered dispensing tools or manual dispensing tools. Cartridges are molded in either standard or low-density Polyethylene.
For more information, please contact the Techcon Systems team at (714) 230-2398 or visit www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in the UK. Today, Techcon represents OK International’s Industrial Product Division. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping to improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves.
For more information, visit the company at www.techconsystems.com.
Dec 18, 2023 -
Techcon Launches New Extra-Large Syringe Barrel, TS60C-LL-N
Mar 21, 2022 -
Techcon is pleased to announce the launch of their new TS9800 Series Jet Valve Dispensing System, the fastest dispensing system available.
Jan 29, 2020 -
Get Smarter Dispensing from Techcon at MD&M West
Jan 16, 2020 -
Techcon to Demo New Jet Valve Dispensing System at APEX
Nov 04, 2019 -
Techcon to Demo New Jet Valve Dispensing System at productronica
Oct 21, 2019 -
Techcon introduces the TS9800 Series Jet Valve for improved speed and productivity in electronics manufacturing
Oct 18, 2019 -
Techcon to Demo Smart Dispensing Robots at The ASSEMBLY Show
Aug 22, 2019 -
Techcon Releases Dispenser for Hassle-free Dispensing of 50ml Dual Syringes
Aug 13, 2019 -
Techcon Demonstrates Smart Dispensing Robots at NEPCON Asia
Mar 18, 2019 -
Techcon to Demo Smart Dispensing Robots at productronica China
109 more news from Techcon Systems »
Aug 09, 2024 -
Jetting Into the Future: Techcon Brings Jet Tech Valve to APEX news release has been viewed 1088 times
Facility Closure
