Techcon Systems, a product group of OK International and a leading provider of fluid dispensing systems and products, will exhibit in Booth #B-1E52 at NEPCON China, scheduled to take place April 26-28, 2016 at the Shanghai World EXPO Exhibition & Convention Center. Company representatives will debut the new TS9300HM Hot Melt Jet Valve at the show and showcase its lineup of industry-leading valves.
TS5624 Disposable Path Material Diaphragm Valve dispenses low to medium viscosity fluids over a wide range of shot and bead sizes, down to a fraction of a micro liter. An internal spring return makes the valves fully adaptable for use with Techcon Systems controllers. A short opening stroke provides an extremely fast and positive shut-off. The seal-less valve design offers excellent moisture sensitive resistance and the incorporated diaphragm creates a barrier between the wetted parts and the air cylinder.
The TS5000DMP Series Auger Valve dispenses material with a rotary displacement action using a rotary feed screw principle. During operation, air pressure pushes the material from the syringe into the feed screw chamber. As the feed screw rotates, the material travels between the threads and out of the dispense tip. The feed screw is driven by the DC motor. The TS5000DMP Auger Valves incorporate a “Disposable Material Path” for single and plural component materials with short cure times.
The TS5540 Series Spray Valves are designed for precise spray applications of low viscosity materials. The TS5540-MS Microshot Spray Valve is designed to spray low viscosity materials through disposable dispensing tips. Spray patterns range from 0.18” to 0.60" in diameter.
Also at the show, the TSR2000 Bench Top Robot Series is ideal for a wide range of fluid dispensing applications, from inline to batch. The versatile TSR2000 dispensing platforms deliver consistent, high-performance dispensing results at an affordable price. The TSR2000 Series is ideal for the following applications: dispense dots of solder paste, form-in-place gasket, filling, potting, encapsulation, bonding, coating and many more. Three models are available (TSR2201, TSR2301 and TSR2401) to accommodate a wide range of working envelopes. The TSR2201 and TSR2301 will be demonstrated at the show.
Techcon Systems also will display the 700 Series Syringe, TE, TT, M Series Needles, along with a range of cartridges and nozzles. Additionally, a wide array of fluid dispensing components will be displayed, ranging from disposable accessories to complete digital controlled dispensing systems and precision valves for automation. For more information, please contact the Techcon Systems team at (714) 230-2398 or visit www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in the UK. Today, Techcon represents OK International’s Industrial Product Division. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping to improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves. For more information, visit the company at www.techconsystems.com.
