Techcon Systems, a product group of OK International and a leading provider of fluid dispensing systems and products, will exhibit in Booth # 1H55 at NEPCON South China, scheduled to take place Aug. 30-Sept. 1, 2016 at the Shenzhen Convention & Exhibition Center. Company representatives will showcase the new TS9300HM Hot Melt Jet Valve as well as Techcon Systems’ lineup of industry-leading valves.
TS5624 Disposable Path Material Diaphragm Valve dispenses low to medium viscosity fluids over a wide range of shot and bead sizes, down to a fraction of a micro liter. An internal spring return makes the valves fully adaptable for use with Techcon Systems controllers. A short opening stroke provides an extremely fast and positive shut-off. The seal-less valve design offers excellent moisture sensitive resistance and the incorporated diaphragm creates a barrier between the wetted parts and the air cylinder.
The TS9200D Jet Tech is a non-contact dispense valve capable of jetting fluid viscosities to 400,000 Cps. Jet Tech offers a fast jetting action producing hundreds of precise droplets in less than one second. The main feature of the valve is a single, easily replaceable diaphragm to eliminate dynamic fluid seals found in other jet valves. No longer is it necessary to disassemble, clean and replace worn seals, which translates into saving time and money. The diaphragm also allows fast cycle rates because of its very small mass. There is no large sliding valve stem that slows down the process. With this novel diaphragm design, the energy needed to eject a drop can be adjusted providing a wider process window.
Company representatives also will showcase consumable plastic containers, including cartridges, bags, etc. For more information, please contact the Techcon Systems team at +44 2380 489 100, Europe-Orders@OKInternational.com or visit www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in the UK. Today, Techcon represents OK International’s Industrial Product Division. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping to improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves. For more information, visit the company at www.techconsystems.com.
