Get Smarter Dispensing from Techcon at MD&M West
Jan 29, 2020
Techcon today announced plans to exhibit in Booth #3063 at MD&M West, scheduled to take place Feb. 11-13, 2020 at the Anaheim Convention Center in CA. The company will showcase its TS9800 Series Jet Valve, TSR2000 Smart Dispensing Robots, TS8100-100 PC Pump with new controller and more.
The TS9800 Series Jet Valve Dispensing System includes the TS9800 Piezo-actuated jet valve and TS980 Smart Controller.  Unlike pneumatic jet valves and other contact dispensing solutions, the TS9800 Jet Valve utilizes Piezo, non-contact jetting technology for increased speed and reduced scrap during the dispensing process.
The Techcon TS9800 Jet Valve provides ultra-fast dispensing speeds and the capability to dispense dots and lines as small as 0.5nL at up to 1500 Hz continuous and 2000 Hz max bursts for higher throughput on a wide range of fluid types and viscosities.
The TS8100 Series Positive Displacement Pump will be shown with the TS580R smart controller. The TS8100 Series is designed to dispense a wide range of fluids, from low viscosity coatings to high viscosity greases. Typical applications include under filling PCBA components, encapsulation and potting applications, applying lubrication on automotive parts, and dispensing pastes and flux.
The TSR2000 series smart dispensing robot is designed specifically for precise fluid dispensing applications and it is compatible with all valve types and controllers. The user-friendly smart PC-based software makes the robot easy to program and simple to operate.
The TS5624DMP Disposable Diaphragm Valve will be on display with a TS550R smart controller. The disposable material path rotary valve is equipped with a quick access hinged door, for rapid feed-path replacement. Techcon’s patented Disposable Material Path (DMP) valve contains a disposable feed screw for easy maintenance and reliable dispensing. With the feed screw made of Delrin®, the valve is designed for use with two-compound and UV fluids.
The TS5540-046R Spray Valves are designed for precise spray applications of low viscosity materials. An external stroke control makes it easy for the operator to fine-tune fluid flow. Total control of the spray cycle is provided by adjustable fluid flow and precise control of prespray, atomizing air and post spray with the TS560R Smart Controller.
Company representatives also will show Techcon’s line of consumables, which includes dispensing tips, syringes, cartridges and nozzles. To learn more about Techcon, visit www.techcon.com.
Since 1961, Techcon has provided precision fluid and adhesive dispensing equipment to a range of service industries, including industrial assembly, aerospace, military, material packaging, medical device and electronics. Techcon products are renowned for their superior accuracy and durability, yielding improved industrial hygiene and enhanced productivity. Our latest innovation is an automatic robotic dispensing system, designed to reduce human error and further increase precision, while providing IoT features such as uploadable instructional files and remote monitoring/troubleshooting. Backed by our expert engineering team, Techcon, an OK International company, is delivering smarter, cleaner, more durable solutions.  www.techcon.com
Dec 18, 2023 -
Techcon Launches New Extra-Large Syringe Barrel, TS60C-LL-N
Mar 21, 2022 -
Techcon is pleased to announce the launch of their new TS9800 Series Jet Valve Dispensing System, the fastest dispensing system available.
Jan 16, 2020 -
Techcon to Demo New Jet Valve Dispensing System at APEX
Nov 04, 2019 -
Techcon to Demo New Jet Valve Dispensing System at productronica
Oct 21, 2019 -
Techcon introduces the TS9800 Series Jet Valve for improved speed and productivity in electronics manufacturing
Oct 18, 2019 -
Techcon to Demo Smart Dispensing Robots at The ASSEMBLY Show
Aug 22, 2019 -
Techcon Releases Dispenser for Hassle-free Dispensing of 50ml Dual Syringes
Aug 13, 2019 -
Techcon Demonstrates Smart Dispensing Robots at NEPCON Asia
Mar 18, 2019 -
Techcon to Demo Smart Dispensing Robots at productronica China
Jan 05, 2019 -
Techcon Brings Smart Dispensing Robots to APEX
109 more news from Techcon Systems »
May 21, 2024 -
May 21, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
May 20, 2024 -
