  • Manage Power Dissipation During Test: Multitest’s MT9510 Provides Extended Temperature Control with XTC
May 06, 2011
MT9510 XP - Tri-Temp Pick & Place Handler
Multitest, a designer and manufacturer of final test handlers, contactors and load boards used by integrated device manufacturers (IDMs) and final test subcontractors worldwide, announces that the MT9510 now provides extended temperature control with its extended temperature calibration (XTC).
Today, more and more ICs, e.g. graphic chips, require a medium range power dissipation control for the device under test (DUT). For most of these applications, it is not appropriate to invest heavily in established active thermal control (ATC) systems. Some semiconductor manufacturers try to solve this by developing proprietary solutions. However, this drains their resources in an area that is not their main business and does not really offer the advantages of a real "turnkey" solution.
Multitest's thermal expertise has enabled the company to develop a unique solution based on XTC for medium range power dissipation up to 50 W. The die temperature inside the DUT is stabilized at a set temperature, avoiding a temperature drift after contacting.
The XTC is integrated into the conversion kit. In addition to cost efficiency, this ensures full availability for any MT9510 pick-and-place handler in the market.
For more information about Multitest's XTC capability on its MT9510, visit http://www.multitest.com/MT9510.
Multitest (headquartered in Rosenheim, Germany) is one of the world's leading manufacturers of test equipment for semiconductors. Multitest markets test handlers, contactors, and ATE printed circuit boards. Globally, more than 700 employees serve the company’s customers in offices and branches in North America, Singapore, Malaysia, the Philippines, Taiwan, China and Thailand.
Mar 29, 2018 -
Mar 13, 2018 -
Dec 16, 2013 -
Dec 02, 2013 -
Nov 25, 2013 -
Nov 18, 2013 -
Nov 11, 2013 -
Sep 09, 2013 -
Aug 22, 2013 -
Jul 15, 2013 -
Manage Power Dissipation During Test: Multitest’s MT9510 Provides Extended Temperature Control with XTC news release has been viewed 1227 times
Void Free Reflow Soldering
