  • A Bundle of New Ideas in Boundary Scan by Market Leader JTAG Technologies
Dec 29, 2014
CoreCommander
CoreCommander
JTAG Technologies, a leader in innovative boundary-scan (IEEE Standard 1149.1) products delivering a broad line of software and hardware tools for test preparation, test execution, test result analysis, and in-system programming applications will demonstrate the latest solutions at IPC Apex 2015 San Diego at booth # 826 :
Versatile new Tool JT 5705 series
JTAG Technologies is proud to showcase the latest in its highly regarded range of boundary-scan controller hardware for PCB assembly and system testing– the versatile JT 5705 series. This completely new design concept incorporates both JTAG/boundary-scan controller functions and mixed-signal I/O channels. Extensive input protection is provided to ensure high levels of in-service reliability and low maintenance. Connection to the tester is via a USB interface.
The first in the series - JT 5705/USB - is supplied as desk-top instrument, primarily aimed at hardware validation applications in design, small-scale production test and in some cases field service and repair. The JT 5705/USB features two 15 MHz TAPs and 64 I/O’s available through 0.1” IDC connectors. 56 of the I/O channels are always digital, 16 of which also feature a frequency function. The remaining 8 channels can be used as either digital I/O or analog I/O. The unit also contains a user programmable FPGA facilitating application specific digital I/O options. Via the built-in ‘Multi-Sync’ feature several JT 5705/USBs can be combined into a single JTAG controller providing multiple TAPs and hundreds of  I/Os.
The second model in this new range is the larger JT 5705/RMI, a 1U high 19” rack-mountable instrument for use in systems or as a bench-top tester. This unit features four 15 MHz TAPs and 4 groups of 64 mixed-signal I/O  channels providing a total of 256 I/O’s available through 0.1” IDC connectors. As before, within each 64 channels group, 56 channels are permanently digital with 16 available as frequency inputs. The other 8 channels of each group can be individually programmed as digital I/O or analog I/O channel. Furthermore the JT 5705/RMI features a total of 4 user programmable FPGA’s for creating application specific digital I/O options.
The I/O capabilities as provided by the JT 5705/USB are also available in a separate I/O module, the JT 5112 Mixed-signal I/O scan module, or MIOS. The MIOS module can be used in combination with existing JTAG Technologies boundary-scan controllers such as JT 3705, JT 3710 and JT 37x7 adding analog I/O capabilities to those controllers.
MD Peter van den Eijnden is convinced of the new solution: ‘We received quite some market feedback on how the next generation of JTAG/boundary-scan testers should look and increasingly we have been asked to provide analog stimulus and measurements alongside more traditional digital I/O systems. The new JT 5705s provides all this and more in really convenient and low-cost package’.
NEW -   CoreCommander and JTAG Translator for FPGAs
Direct access to memory and peripheral controllers in FPGAs for testing, debugging and in-system programming.
  • Direct access to memory and peripheral (I/O) controllers in an FPGA through its JTAG interface
  • Read data from, write data to memory and peripherals without software programming
  • At-speed execution of read and write cycles
  • Testing and debugging of the connections between an FPGA and memory and peripherals with at-speed bus cycles without software programming
  • Easy programming of flash memory without software programming
JTAG Translator is an IP1 module from JTAG Technologies that provides a JTAG interface to the internal IP connection bus of an FPGA to which peripherals / peripheral controllers are connected. JTAG Translator is operated through a dedicated  CoreCommander that can be used with JTAGLive and ProVision as well as with all our production packages. CoreCommander provides high-level functions to write data to and read data from memory and I/O addresses without software programming. CoreCommander functions are applied via the JTAG interface. The JTAG Translator IP module can be loaded in the FPGA for test configurations only, or it can be included as standard in functional designs
With JTAG Translator the IP blocks which are already used in a design can be re-used for test or in-system programming purposes. Examples of existing IP blocks are interface controllers for SDR, DDR, Ethernet Mac, USB, UART, I2C, CAN, etc… These are readily available from different IP suppliers like Altera, Xilinx, OpenCores, etc.
JTAG’s Acclaimed ProVision Software
The JTAG ProVision software suite is used to generate boundary-scan tests and in-system programming applications for assembled PCBs and systems. This professional development tool is fully automated and supports the import of design data from over 30 different EDA and CAM systems.
JTAGs’ ProVision greatly simplifies the test engineer’s main task - to develop reliable tests with the best possible fault coverage for failures that may occur during PCB (printed circuit board) assembly. ProVision’s advanced technology allows many tests to be generated automatically, for all others ProVision includes tools to assist engineers to develop alternatives easily.
Here some of the main Product Highlights:
  • Unified graphical user interface (GUI) for all test and programming applications
  •  Wizards guide the development process
  •  Automated, advanced generation tools
  •  Comprehensive device model library
  •  Full Python API for custom scripted applications
  • Built-in Fault Coverage Analyser
  •  Graphical view and control of nets and devices
  •  Choice of fault reporting and diagnostic views
  • Built-in sequencer for factory ready test plans
JTAG Technologies is a market leader and technology innovator of boundary-scan software and hardware products and services. The company was the first to bring to the market such important advances as automated test generation, automated fault coverage analysis, automated flash and PLD programming via boundary-scan, and visualized boundary-scan analysis. Its customers include world leaders in electronics design and manufacturing such as Ericsson, Flextronics, Honeywell, Medtronic, Motorola, Nokia, Philips, Raytheon, Rockwell-Collins, Samsung, and Sony. Its innovative boundary-scan products provide test preparation, test execution, test result analysis and in-system programming applications. With an installed base of over 6500 systems worldwide, JTAG Technologies serves the communications, medical electronics, avionics, defence, automotive, and consumer industries with offices throughout North America, Europe and Asia. JTAG Technologies headquarters are located in Eindhoven, The Netherlands.
JTAG and JTAG Technologies are registered trademarks of JTAG Technologies, Inc. All other brand names or product names mentioned are trademarks or registered trademarks of their respective holder(s).  www.jtag.com
Follow us !
JTAG Technologies and JTAG Live are on Twitter, Facebook, Google+,LinkedIn and YouTube. Follow us to keep up to date of all the latest news!
Oct 27, 2018 -
JTAG Technologies - 25 Years of Innovation and Dedication to Boundary Scan
Jan 16, 2018 -
Preview for IPC Apex 2018 San Diego, booth # 3007 JTAG Visualizer Update Adds Features for Faster Debug Assess PCB assembly fault coverage and find board build errors quicker
Nov 07, 2017 -
Preview for productronica 2017 JTAG Visualizer Update Adds Features for Faster Debug
Sep 10, 2017 -
JTAG Technologies’ Preview for IEEE Autotestcon 2017, Booth 721, Schaumburg, Illinois, September 14th-17t
Aug 26, 2017 -
Preview for JTAG Technologies for SMTA International - Schaumburg, Illinois Chicago, booth # 228, 19th to 20th September 2017
May 22, 2017 -
Preview for Jaarbeurs Utrecht, 30th May to 1st June 'Electronics and Applications' Show JTAG Technologies Booth # 7E018
Jan 04, 2017 -
Press Preview for IPC Apex 2017, San Diego Conference Center, Booth 3435 14th to 16th February 2017
Nov 09, 2016 -
Map your JTAG Test Access with Altium Designer
Sep 20, 2016 -
JTAG Technologies for SMTA Show Rosemont IL, USA, booth # 136
Sep 05, 2016 -
JTAG Technologies’ Preview for Autotestcon 2016 Booth # 826, Anaheim September 12-15,
26 more news from JTAG Technologies B. V. »
Oct 15, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 13, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
Oct 06, 2024 -
A Bundle of New Ideas in Boundary Scan by Market Leader JTAG Technologies news release has been viewed 1077 times
