  • Bentek Solar Introduces PV 101 MDSS for Safety and Code Compliance
Oct 02, 2012
 MDSS
MDSS
 Bentek Solar, a leading designer and manufacturer of PV products connecting PV panels to inverters for the commercial and utility-scale marketplaces, announces that its MDSS is a cost-effective means for providing safety and code compliance for PV installations.
The MDSS contains a bank of load-break disconnects in a compact, free-standing cabinet. Typically, the MDSS is installed next to the inverter and provides the safety and arc flash reduction that is needed in all photovoltaic (PV) systems, solving a critical safety issue that is commonly overlooked. The MDSS provides code-compliant fuse isolation that inverters do not. This allows fuses in the inverter to be removed safely.
Multiple sources of power are much less common in AC applications. As a result, PV installations contain hazards that many electricians and maintenance personnel are not accustomed to. Contact with a live fuse that has 600 or 1000V of electricity present may result in death. To help prevent this, National Electrical Code (NEC) 2011 690.16 states that, "an external disconnect must be installed within the line of sight of the inverter fuses or at a distance not greater than 50 feet from the inverter fuses." However, not all states follow this NEC rule. This should be of great concern not only for the installers but also for the operations and maintenance (O&M) organization that will need to maintain the PV system for years to come.
Bentek Solar’s MDSS with optional zone current monitoring is optimized to work with most inverters at both 600 and 1000VDC. The number of inputs and ampacity of the load-break disconnects in the MDSS are matched to the number and ampacity of the internal inverter fuses. This ensures that when the MDSS arrives at the project site, it is simple to install by eliminating extra racking, conduit and expensive labor that is required with traditional individual knife blade disconnects, saving up to 30 percent in total cost. The installer typically runs the cables up through the bottom of the MDSS and connects one cable to each input and one cable to each output. Each output cable then runs to an inverter fuse. For example, if the inverter has eight internal fuses that are 400A each, the MDSS would contain eight 400A load-break disconnects, with each disconnect connecting to an inverter fuse.
For more information or to view online cut sheets, visit www.BentekSolar.com.
Founded in 1985, Bentek is a leader in manufacturing and engineering solutions for complex electro-mechanical and power distribution systems for the semiconductor and solar industries. Bentek has applied these extensive capabilities and knowledge into a comprehensive family of standard and configure-to-order (CTO) solar combiner products. These solar combiners provide quality, ease of installation and safety to the solar industry. For more information, contact Bentek Solar at 866-505-0303, e-mail SolarSales@bentek.com or visit www.BentekSolar.com.
Dec 05, 2015 -
Bentek Solar Receives Multiple Patents for Its Inverter PowerRack and PowerSkid
Sep 14, 2015 -
Bentek to Exhibit New Residential, Commercial and Utility-Scale PV Products in Booth #3314 at SPI
Jul 13, 2015 -
Bentek Adds Second Manufacturing Shift to Meet Customer Demand
Jun 24, 2015 -
Bentek Expands Cable Harness Capacity in New Solar Manufacturing Facility
Jun 09, 2015 -
Bentek’s Inverter PowerRacks Gaining Customer Acceptance
Jun 02, 2015 -
Bentek Continues to Expand AC Product Line with New Utility-Scale AC Recombiner
May 15, 2015 -
Bentek’s Power Economizer Integrated into RSS Reduces Power Consumption by 50 Percent
May 03, 2015 -
Bentek’s Residential Rapid Shutdown System Gaining Customer Acceptance
Mar 09, 2015 -
Bentek Expands Manufacturing Capacity to more than 100,000 ft.2
Jan 16, 2015 -
Bentek Begins Shipment of Universal PowerRack-AL
36 more news from Bentek Solar »
Aug 01, 2024 -
JONATHAN BEAUDEAU SLANDERED!
Jul 29, 2024 -
SMTA International Technical Conference Program Announced
Jul 29, 2024 -
Jul 29, 2024 -
Murray Percival Company Expands Product Line with Representation of BIMOS ESD Seating in the Midwest
Jul 29, 2024 -
Jul 29, 2024 -
PEMTRON Announces Partnership with American Tec for Distribution in China
Jul 29, 2024 -
Jul 26, 2024 -
Jul 22, 2024 -
Jul 22, 2024 -
Bentek Solar Introduces PV 101 MDSS for Safety and Code Compliance news release has been viewed 863 times
Facility Closure
