  • Bentek to Exhibit New NEC 2014 Rapid Shutdown Solutions at SPI Las Vegas
Oct 07, 2014
PowerRack
PowerRack
Rapid Shutdown Controller (RSC)
Rapid Shutdown Module (RSM)
Bentek, a manufacturer of a broad range of OEM power distribution products for the residential, commercial and utility-scale solar PV marketplaces, will exhibit in Booth #360 at Solar Power International (SPI), scheduled to take place Oct. 20-23, 2014 at the Las Vegas Convention Center in Las Vegas, NV. Bentek will introduce several new UL listed solutions that enable string inverter compliance with the NEC 2014 rapid shutdown requirements.
Company representatives will showcase the following equipment: the Rapid Shutdown System (RSS), PowerRack and PowerShield, PowerSkid with integrated inverter, DC connection unit, and Bentek AC Disconnect and AC PowerBUSS. The Bentek RSS solution provides the PV marketplace with a universal design that is compatible with any inverter type. The PowerRack has been optimized for string inverters from ABB, Advanced Energy, Chint Power Systems, Fronius, Schneider, SMA, SolarMax and Solectria.
The patent pending Bentek Residential and Commericial Rapid Shutdown System (RSS) is a complete stand-alone solution that is highly cost effective and easy to install. It includes two components; the Rapid Shutdown Controller (RSC) installed at the service entrance and a Rapid Shutdown Module (RSM) installed at the array.
The Bentek PowerRack and PowerShield provide installers with an easy, cost effective way to install three-phase string inverters directly on flat commercial rooftops at the edge of the PV array, meeting the requirements of NEC 690.12.
The Bentek PowerSkid is a PowerRack with fully integrated three-phase inverter, Bentek AC disconnect and other accessories.
The Bentek AC PowerBUSS combines the AC output of three-phase string inverters and provides overcurrent protection and disconnecting means prior to the service panel. The AC PowerBUSS can be integrated with a Bentek PowerRack and installed on flat commericial rooftops next to the three-phase inverters.
For more information about other Bentek’s entire suite of PV solutions, stop by Booth #360 at SPI in Las Vegas, call Bentek at 1-866-505-0303 or visit www.Bentek.com.
Founded in 1985, Bentek is a leader in engineered electromechanical and power distribution solutions for industrial applications. Bentek designs and manufactures products such as wiring harnesses, electrical combiner boxes, and custom OEM assemblies for the solar energy and semiconductor markets. Bentek is an ISO certified company. For more information, contact Bentek Solar at 866-505-0303, e-mail SolarSales@bentek.com or visit www.Bentek.com.
Dec 05, 2015 -
Bentek Solar Receives Multiple Patents for Its Inverter PowerRack and PowerSkid
Sep 14, 2015 -
Bentek to Exhibit New Residential, Commercial and Utility-Scale PV Products in Booth #3314 at SPI
Jul 13, 2015 -
Bentek Adds Second Manufacturing Shift to Meet Customer Demand
Jun 24, 2015 -
Bentek Expands Cable Harness Capacity in New Solar Manufacturing Facility
Jun 09, 2015 -
Bentek’s Inverter PowerRacks Gaining Customer Acceptance
Jun 02, 2015 -
Bentek Continues to Expand AC Product Line with New Utility-Scale AC Recombiner
May 15, 2015 -
Bentek’s Power Economizer Integrated into RSS Reduces Power Consumption by 50 Percent
May 03, 2015 -
Bentek’s Residential Rapid Shutdown System Gaining Customer Acceptance
Mar 09, 2015 -
Bentek Expands Manufacturing Capacity to more than 100,000 ft.2
Jan 16, 2015 -
Bentek Begins Shipment of Universal PowerRack-AL
36 more news from Bentek Solar »
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
Jun 10, 2024 -
James Will to Lead USPAE as New Executive Director
Jun 10, 2024 -
Amtech Continues to Attract New Customers with Proven Vapor Phase Technology
Jun 07, 2024 -
Jun 06, 2024 -
Bentek to Exhibit New NEC 2014 Rapid Shutdown Solutions at SPI Las Vegas news release has been viewed 934 times
