XJTAG Extends the Power of Boundary Scan Testing
Jul 16, 2019
XJTAG 3.9 now available for download from www.xjtag.com
Cambridge, UK, July 16, 2019 — XJTAG, a leader in boundary scan test solutions, announces the release of its latest software that helps engineers develop better test programs and operate more efficiently. XJTAG 3.9 introduces a new API that brings boundary scan’s power of individual pin control into a developer’s own test code, an editor that allows device models to be created that have configurable options for maximum reuse, and data-rich log files that are now even easier for existing systems to analyse.
Following requests from clients, XJTAG has introduced an API that allows engineers to use XJAnalyser’s ability to manipulate the pins of JTAG-enabled ICs in their own software with almost no set up. This gives developers the ability to enhance non-JTAG tests: for example, a test routine can use the API to set control lines on a board to enable / disable individual power rails during testing; and to receive notifications if monitored pins change state. This provides engineers with much-needed flexibility when designing functional tests. The API has been written for C#, Visual Basic and other .NET environments, and works with test executives such as National Instruments’ LabVIEW™, TestStand™ and LabWindows™/CVI. It is available to any user with an XJTAG system that includes XJAnalyser, and come with example projects in Visual Studio, LabVIEW and TestStand that demonstrate how to use the API.
For engineers working with XJDeveloper, categorising new devices is now even more efficient thanks to an editor that allows users to add configurable options to model files. This enables a single file to support a device with parameters that may want to be changed between different implementations (such as an I²C device that can be set to different addresses) as well as allowing a designer to include adjustable parameters (e.g. to vary the amount of text output or to change a memory’s programming method). This gives engineers the ability to create flexible device models that can easily be reused, making their work simpler and more efficient.
When it comes to performing boundary scan tests, the machine-readable log files now have an enhanced structure with new keywords that makes it even easier for a computer to extract information. The file format has been documented so that the output from boundary scan tests can be incorporated into results databases without difficulty, giving operators the ability to track the history of units throughout the entire production line using already-established systems.
This latest release demonstrates XJTAG’s continued leadership in boundary scan technology and the company’s on-going commitment to introducing ever more powerful tools into the testing arena while simultaneously making engineers’ tasks simpler and more efficient.
XJTAG 3.9 is available now for download from www.xjtag.com for existing clients with a valid maintenance contract. Fully-featured trials with free initial test project setup are available at no charge to new clients, and more information can be found at www.xjtag.com. XJTAG can be contacted via enquiries@xjtag.com.
About XJTAG
XJTAG is a world leading supplier of JTAG boundary-scan hardware and software tools. The company focuses on innovative product development and high quality technical support. XJTAG products use IEEE Std.1149.x (JTAG boundary-scan) to enable engineers to debug, test and program electronic circuits quickly and easily. This can significantly shorten the electronic design, development and manufacturing processes. For more information about the company, its products and its services, please visit www.xjtag.com
Sep 03, 2024 -
XJTAG Shows the Benefits of Boundary Scan at FPGAworld
Mar 28, 2023 -
XJTAG Makes Boundary Scan Project Creation Easier & Faster
Mar 22, 2022 -
XJTAG 3.12 Boosts Focus, Flexibility and Convenience
Oct 19, 2021 -
XJTAG Ultra-Fast Flash Programmer
Jun 16, 2021 -
XJTAG Introduces Arm® SWD Support and User-Defined Libraries
Feb 19, 2020 -
XJTAG Boundary Scan 3.10 Delivers Great Ease-of-Use
Nov 11, 2019 -
XJTAG Million Dollar Product Giveaway
Nov 20, 2018 -
XJTAG wins Innovator of the Year award from DESIGN&ELEKTRONIK
May 10, 2018 -
Free XJTAG DFT Assistant Offering for Mentor Xpedition Customers
Feb 22, 2018 -
XJTAG Announces DFT Assistant for Zuken CR-8000 PCB design suite
9 more news from XJTAG »
Sep 09, 2024 -
SEHO to Exhibit at productronica India
Sep 09, 2024 -
SIEMENS 700-443-0TP01 S7-TCP/IP 200-8000-01
Sep 09, 2024 -
SIEMENS 6ES5482-4UA20
Sep 09, 2024 -
ESTIC ENRZ-AU30
Sep 09, 2024 -
EMERSON KJ3201X1-BA1 12P2535X042 VE4001S2T2B2
Sep 09, 2024 -
WHEDCO IMC-4230-1-B
Sep 09, 2024 -
ABB HIEE305082R0001 UNS0863A-P V1
Sep 09, 2024 -
SEW DFI21B Inverter bus communication card
Sep 09, 2024 -
HONEYWELL 51196742-200 Module
Sep 09, 2024 -
BENTLY NEVADA 16925-33
XJTAG Extends the Power of Boundary Scan Testing news release has been viewed 1052 times
