  • Digitaltest presents advanced Applications and Quality Management Tools at productronica, Munich (Germany), Booth A1-365, November 12th to 15th, 2013
Oct 17, 2013
MTS 30 Sparrow – High Quality Test and Outstanding Flexibility
Digitaltest GmbH, a renowned supplier of Electronic Board Test Systems & Electronic Manufacturing Software Software.
At booth A1-365, Digitaltest presents sophisticated and customized test solutions for your production. Discover our extensive product range, including:
In-circuit-, functional- , flying probe test systems, CAD/CAM software and quality management software.
MTS 30 Sparrow - High Quality Test and Outstanding Flexibility
Digitaltest's Sparrow provides the highest level of flexibility and test capability in a small footprint. As a result of combining ICT, enhanced switching and test capabilities with comprehensive functional test in a compact rack mount platform, the Sparrow system is used in many of the world’s most demanding manufacturing lines. Technical features include: comprehensive in-circuit and functional tests, integrated boundary-scan tests, on-board memory programming as well as the integration of PXI and IEEE test systems. The Windows based system, running Visual Studio, is available as space-saving 19 inch rack-mount system.
New Fast Access Interface (FAI) - Maintenance and Change-Over Improved
To further enhance the integration of the system a new quick-release interface is now available for the system. On multi-instrument systems this may significantly ease system extension, system diagnosis and maintenance.
New UPC02 Assembly - Saves Space in the System and Cuts Costs
UPC02 consists of a UPC controller module and a fixed voltage source. It is considerably smaller than its predecessor power supply assemblies. Without any additional power supply rack up to four UPC02 can be integrated into a Sparrow system.  To ease maintenance, UPC02 controllers are easily accessible via a slot on the rear of the Sparrow system.
MTS 300 Sigma - Lambda Edition with a Single PC – Reduced Footprint and Simplified Operation
The Lambda Edition of the Sigma system is capable of testing two or more different test units in real parallel test.  This can decrease test time by 50% with 2 test units, 75% with 4 test units etc. Due to its CITE6 based software only a single PC is required.
MTS 500 Condor
The high performance flying probe system provides high accuracy probing, easy programming, standard tests and opens check.
Digitaltest’s Condor system is well known for its speed and accuracy. It consistently provides the performance to tests prototype boards and small to medium batches in a streamlined and cost-effective manner. Moreover, the integrated Sparrow system is capable to run external board tests in larger batches. Another way of higher throuput is by smart optimization with SNAP (Simple Note Access Pin) or fixtures used inside the flying prober.
In addition to its standard features the system offers:
  • Analog & digital ICT, FCT, Vision test and boundary scan integration
  • High accuracy probing based on linear planer motion
  • Save back-driving - latest technology drivers/sensors
  • Rapid programming using the integrated CAD and test software
  • High throughput, smart optimization tools
  • Remote maintenance through optional web cam
Digitaltest will be pleased to showcase the latest improvements of the current Condor software release:
  • Enhanced Simple Note Access Pin (SNAP) placement
  • Improved live camera mode
  • Enhanced accuracy
  • Improved operator convenience of the graphical system control software GenFast
CITE 6 with new Programming Language VB.NET - Provides Modern Communication Features
With the introduction of CITE 6 the user can benefit from Visual Basic.NET (as part of Visual Studio 2010/2012) – in addition to Visual Basic 6. The test program is now part of the .NET world and all modern communications options are available. Its up-to-date programming language enables CITE 6 to communicate between test program, user software, operating system, and hardware components.
C-LINK - Advanced CAD Converter Solutions
The CAD/CAM software C-LINK DTM imports and processes assembly layout data, bill of material and schematics data. It runs probability and testability analyses for feedback to development department or production release. With its comprehensive range of output filters for fixture construction, AOI, and flying probe test systems C-LINK is the perfect tool to speed-up NPI processes and increase the quality levels of fixtures and test programs.
The latest version of C-LINK will be presented at the show.
QMAN - Paperless Repair Software
QMAN is a quality management software suitable for all MTS and third party test systems. QMAN gathers fault messages from visual inspection stations or automated test systems. It helps to reduce repair time and costs featuring powerful tools like layout graphics and schematics and offers detailed history data of the specific board including all previously taken repair measures. In addition, repair data may be used to identify possible failure trends and issue appropriate alarms or prepare statistics data and thus increase transparency of production quality levels and comparability.
The latest version of QMAN will be demonstrated at the show.
Digitaltest has been developing and manufacturing Automated Test Equipment (ATE) for electronic printed circuit boards (PCB), software for production automation and quality management systems for more than 30 years.
Digitaltest has created innovative and often pioneering solutions that integrate CAD, test and production to optimize the entire manufacturing process. Digitaltest also offers extensive service and support options, up to complete outsourcing of your board testing requirements at any of our facilities all over the globe.
Digitaltest hardware and software is being used in key industries including aerospace, avionics, automotive, telecommunications, medical, industrial and consumer electronics and more. With over 2,500 installations around the world, Digitaltest is a trusted partner to the industry. www.digitaltest.net
Jan 16, 2017 -
Digitaltest To Show Their Latest Condor Flying Probe System, New CAD/CAE Software Packages And Back-end Quality Management Software Releases at IPC APEX EXPO 2017
Sep 12, 2016 -
Digitaltest Germany's success continues with new, expanded production site
Mar 15, 2016 -
Digitaltest to show their new flying probe system, the Condor MTS 505 and reverse engineering software, Digitizer 2.0 at IPC Apex EXPO 2016.
Mar 08, 2016 -
Lenze Americas deploys Digitaltest’s MTS 30 Combinational In-Circuit/Functional test platforms to provide the highest quality to their customers.
Mar 07, 2016 -
Jan 05, 2016 -
Digitaltest to show their new flying probe system, the Condor MTS 505 and reverse engineering software, Digitizer 2.0 at IPC Apex, Las Vegas, NV, Booth 1547, from March 15th to 17th, 2016
Oct 22, 2015 -
Digitaltest introduces their new innovative CAD Recovery Software
Oct 05, 2015 -
Digitaltest Introduces Their New Flying Probe Tester at Productronica 2015
Apr 26, 2015 -
Preview for Digitaltest GmbH and Romex B.V. for the Electronics Automation Exhibition in Utrecht, the Netherlands, Booth 8B 062, May 25th to 27th
Apr 13, 2015 -
Digitaltest adds Process Automation to its North American sales channel
11 more news from Digitaltest Inc. »
Jul 09, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Jul 08, 2024 -
Digitaltest presents advanced Applications and Quality Management Tools at productronica, Munich (Germany), Booth A1-365, November 12th to 15th, 2013 news release has been viewed 1163 times
