In PCB assembly line, the smt first article inspection process is a critical important step.
What is first article inspection for PCB?
Beginning of the SMT production line or changed, the first product to be processed is called the first article. A series of inspection on the first PCB Board produced is called SMT first article inspection. The inspection including measuring ( resistance, capacitance, inductance) component values, confirming component position, component polarity, component orientation, component presence or absence etc. )
The SMT first article inspection system in PCBA manufacturer is an effective measure to detect the problem as early as possible and prevent the occurrence of unqualified products in batch. Can check the placement machine program error (position, direction, polarity, more pieces, less pieces), FEEDER station installation error, material error and a series of errors.
First article inspection procedureļ¼
1. Import BOM
Review BOM and automatically obtain component span
2. Read in the original coordinates
Import original CAD data, combine with BOM, automatically generate the first program.
3.Automatic testing of LCR components
Fully automatic test of LCR components, self-determining test results.
4. Automatically identify non-LCR
Visual automatic comparison of screen printing and polarity, automatic identification of blank components.
5. Output test report
One key to generate a detailed test report, upload it to MES.
What are the Advantages of using First Article Inspection Machine?
1.Save Labor
2. Improve inspection efficiency
3. Quality Guarantee
4. Automatic judgment system
5. Accurate and efficient
6. Traceability
7. Inspection Report
8. MES system: Interconnects with MES system
I.C.T-FAI86M is a self-developed and produced flying probe first article inspection machine that uses a group of flying probes to automatically change the span and automatically test LCR components.
Purpose of first article inspection on PCB Assembly line is to increase the plant`s Return On Investment ( ROI )
If you want to save labor, save time and improve ROI, it`s a better choice to use SMT first article inspection machine. Please contact market@smt11.com There will be more Solution for you to choose.
I.C.T – Your Reliable Dearest Partner
For you we can provide Full SMT Line Solution, DIP Line Solution and Coating Line Solution with best quality and service.
www.smtfacory.com www.smtmachineline.com
