How to choose Automatic Insertion Machine?
May 27, 2023
I.C.T Through Hole (Axial & Radial) Automatic Insertion Machine
Automatic Insertion Machine is the Key to Efficient and Accurate Component Placement for PCB Assembly.
Insertion machines are essential tools for any manufacturer of electronic products. These machines automate the process of placing components on printed circuit boards (PCBs), which can save manufacturers time, money, and improve the quality of their products. They work by using a vacuum pick-and-place mechanism to pick up components from a feeder and place them in the correct holes on the PCB. The machine has a vision system that helps to ensure that the components are placed in the correct orientation.
Types of Insertion Machines:
There are two main types of SMT insertion machines: axial and radial.
Axial insertion machines are used for components with leads that are parallel to the PCB, while radial insertion machines are used for components with leads that are perpendicular to the PCB.
Next, let's have a look at the two types of insertion machines.
I.C.T-Z3020 Radial Insertion Machine
I.C.T-Z3020 Online Radial Insertion Machine
-Strong Machine Flexibility
• Expandable from 10 inputs up to 100 inputs
• Inserts at 1 degree increments up to 360 degrees
• Inward clinch option to increase bottom side density
- Lowers Cost of Ownership
• Low Energy costs
• Minimal preventative maintenance required
- Easy to Use User Interface
• Easy operation, use Excel program and USB input.
• Off-line programming available
• Components available: Capacitors (electrolytic, ceramic, box, and film), transistors, diodes,
LED, connectors, tact switches, coils, potentiometer, lamps, fuses, etc.
  Get More
I.C.T-Z4020 Axial Insertion Machine VI
I.C.T-Z4020 Online Axial Insertion Machine
•  Expandable from 20 stations.
•  Low-maintenance feeder technology.
•  Dual part detection – two parts in the same chain slot.
•  Insertion Directions: 0°, 90°, 180°, 270°, 360°.
• Jumper Wire Feeder Support.
• Neighbor components parallel distance E(pitch)=5.0mm
• Tape width: 52mm
• Max Component Body Length: C=16mm, Resistor: 1/8W-2W
• Axial Lead Component Kind: Diode, Resistor, Capacitor, etc.
• Max body diameter D=5.0mm
  Get More
I.C.T - Your Reliable Dearest Partner
For you we can provide Full SMT SolutionDIP Solution and Coating Solution with best quality and service.
More information about I.C.T please contact US at info@smt11.com
More information please visit: www.smtfactory.com / www.smtmachineline.com  / www.smt11.com
May 30, 2024 -
May 15, 2024 -
I.C.T Supporting EMS Manufacturers for Indonesian customers
May 13, 2024 -
I.C.T Global Technical Support for Customized SMT Reflow Oven in Malaysia
Apr 29, 2024 -
SMT AOI Machine: Revolutionizing SMT Inspection with AI Technology
Apr 23, 2024 -
New Energy Automotive: I.C.T.'s Conformal Coating Line Expertise in Mexico
Apr 16, 2024 -
I.C.T | Your One-Stop Service for Smart Meter SMT Factory
Apr 09, 2024 -
Select the Perfect PCBA Coating Machine Line
Mar 27, 2024 -
Red Glue SMT Solutions: A Cost-Effective Approach for Double-Sided PCBs
Mar 21, 2024 -
Precision in Motion: The I.C.T Solder Paste Jetting Machine for 5G Applications
Mar 19, 2024 -
Made in Japan: Solder Paste Jet Dispensing Machine
86 more news from I.C.T ( Dongguan ICT Technology Co., Ltd. ) »
Jun 28, 2024 -
Jun 26, 2024 -
Jun 25, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
Jun 24, 2024 -
How to choose Automatic Insertion Machine? news release has been viewed 1242 times
SMT Machines china
