Achieving Precision with the I.C.T-GV330 Guillotine PCB Separator
In the world of PCB assembly and electronics manufacturing, precision and efficiency are essential. The I.C.T-GV330 Guillotine PCB Separator, a professional guillotine-type automatic PCB V-cut machine, is here to excel in the realm of PCB separation.
Key Features of I.C.T-GV330 Guillotine PCB Separator
Let's dive into the exceptional features that make the I.C.T-GV330 stand out:1. Minimal Internal Stress: This separator minimizes internal stress during separation, preventing solder cracks and component damage.
2. Precision Separation: It accurately separates V-slots, maintaining a minimal 0.3mm distance from components with a maximum height of 60mm.
3. Blade Maintenance: The machine allows for free blade sanding, ensuring consistent cutting performance over time.
4. Pneumatic Control: Controlled by a pneumatic foot-plate switch, it maintains a precise cutting speed of one cut per second.
5. Safe and Controlled Separation: The negative blade activation ensures the safety of the separation route and position control.
6. Minimal Pollution: It's an environmentally friendly choice as it doesn't create carbon or dust pollution like motor-driven separators.
7. Residue-Free Separation: Due to its non-friction-based separation method, no metal residue is left behind, maintaining a clean process.
8. Exceptional Durability: With a lifespan of over 6,000,000 cycles, it's a robust and reliable addition to any PCB assembly line.
9. Professional Guillotine Type: Designed specifically for FR4 board processing, it's a professional guillotine-type automatic PCB V-cut machine.
Enhancing Efficiency with I.C.T-GV330
Efficiency is the core of the I.C.T-GV330 Guillotine PCB Separator. Its quick and precise operation streamlines PCB separation, making assembly lines more efficient.Ideal for applications where precision matters, the I.C.T-GV330 provides consistent and reliable results, whether with delicate SMT components or thicker PCBs.
Its non-rotational separation method reduces the risk of pollution and machine wear, making it a sustainable and eco-friendly choice for electronics manufacturing.
Explore Other PCB Separator Options
Discover other PCB separator options to meet your specific needs:LED Separator: Ideal for precise LED PCB separation.
Manual PCB V-Cutting Machine: Provides flexibility for customized PCB separation.Moving Blade PCB Separator: Efficient and safe with hand and foot controls.
Multi-Group Blades PCB Separator: Multiplies efficiency for splitting multiple LED strips.
PCB Router: Suitable for cutting curved surfaces.
Laser PCB Router: Provides high-precision cutting, including semiconductor applications.
Craft perfection in PCB separation with the I.C.T-GV330 Guillotine PCB Separator.
